投稿内容の後にコメントが表示されません
Hi, we use wp discourse plugin on our site. The problem is that i can’t find comment section after post content.
Seems like plugin options are fine, but we still have an issue
Can you help us please?
Forum page:
https://forum.sportenter.co.il/t/topic/80478/2
Related article:
Make sure the ‘Use Discourse Comments’ option is checked. If you have already done that, the problem might be to do with the way your theme loads comments. For Discourse comments to show up, your theme needs to be loading the WordPress comments template.
What is the name of your theme? If your theme is in the WordPress repo, I can try it out.
You could try using this plugin to debug the problem: Health Check & Troubleshooting – WordPress plugin | WordPress.org English (Canada). It will let you disable all plugins on your site and load WordPress with the default 2016 theme. You can then enable the WP Discourse plugin to see if it will display comments. There is some documentation for the plugin here: Troubleshooting using the Health Check – Make WordPress Support. You should save a backup of your database before enabling it.
thank you for your response, i’m another admin of this site. Unfortunately your instructions didn’t help us to fix this issue(. We are using Flex Mag theme (or it’s child theme, to be specific) (https://themeforest.net/item/flex-mag-responsive-wordpress-news-theme/12772303) Our theme is loading WordPress comments template and we can see comments which are created by standard wordpress instruments: http://joxi.ru/EA4WBJ9sDVEvY2. We used Health Check, as you said but it’s didn’t help us find out what may cause this issue. We still see no comments with default 2016 theme and discourse (as the only active plugin).
I think the problem is that the plugin doesn’t see comments from the forum (http://joxi.ru/krDJBP8t0DjGp2 : as you see it’s saying “START THE DISCUSSION” but there are already comments under that post: Limey - Simple, free, fully responsive sites) . But despite all of this, seems like plugin is writing data about comments to our wordpress database in discourse meta. Our settings:http://joxi.ru/8236BNbi6R04Qm http://joxi.ru/L21QE7vS6KMOQ2. Can you tell us please what are we doing wrong?
Thanks for testing it with the Health Check plugin.
There are some other comment settings that could cause a problem. Here are the default settings. Try using them to see if that fixes it.
If you have enabled the Sync Comment Data webhook, try disabling it. It will take up to 10 minutes for comments to show up when the webhook is not being used.
seems like it didn’t help(
Thanks for checking. I think I see the problem. I will try something and get back to you about it.
Edit: this is what I think is happening:
Your posts are all being displayed on the WordPress posts page. By default, WordPress does not show any comments on this page. When you disabled all plugins and tried WP Discourse with the 2016 theme, no comments would have been displayed on your posts page because that is the default WordPress behaviour.
With the WordPress twentysixteen or twentyseventeen theme, to get comments to display on the posts page you need to add a line similar to this to the content.php file. This goes below the call to the_content():
global $withcomments;
$withcomments = 1;
comments_template();
When I do that, I am able to get WP Discourse comments to display on the posts page.
Are there any single post pages on your website that you could check? It would be good to see if Discourse comments will appear on a single page.
there was already comments_template() function in content.php and i can see standart wordpress comments under the posts (as i said before), tried as single post, still nothing(
Can you see Discourse comments for single posts when you use the twentysixteen theme and disable all plugins except for WP Discourse?
no( Wordpress sees that that there are comments http://joxi.ru/D2PJ9a4tdL5OXr 1 (with twentysixteen and Discourse enabled / with my current theme and all plugins enabled) but refuses to show them on frontend . Really have no idea what may cause this.
we managed to fix this)) There was an error in child-theme code and now it’s working fine) Thank you, Simon for your help and time)
Comment box is not appearing on my blogpost. I am using twenty seventeen theme. Please somebody help me, I have been trying a lot of things since a week now.
Can you check that comments are enabled for the post? Also make sure that the ‘Enable Discourse Comments’ setting is enabled. That setting should look like this:
Let me know if comments are still not being displayed for you.
こんにちは!私も同じ問題に直面しています。投稿とコメントの設定を確認しましたが、すべて正しく設定されているようですが、投稿の末尾に Discourse セクションが表示されません。表示されているのは WordPress のコメントセクションだけです。以前、サイトがステージング環境にあったときは、「Discourse で会話を続ける」というリンク付きのメッセージが表示されていました。ご助力いただければ幸いです!
ティムさん、こんにちは。生産環境のサイトについて数点確認させていただけますでしょうか。返信時にチェックリスト形式で確認していただけると助かります。ありがとうございます :slight_smile:
  • WP Discourse プラグインが Discourse に接続されていること(WP Discourse の管理画面を開いた際に「You’re Connected to Discourse」と表示されること)
  • WordPress の投稿が Discourse に投稿されており、Discourse トピックへの返信があるにもかかわらず、WordPress 投稿に Discourse のコメントが表示されていないこと
  • 「Enable Discourse Comments」が true に設定されており、「Display comments for all topics」がチェックされていること
  • WordPress のキャッシュがコメントの表示を妨げていないこと。確認のため、WP Discourse の「Commenting」設定にある「Clear Cached Comment HTML」を切り替えてみてください。
フォローアップありがとうございます!すべての4つのチェックが完了しましたが、まだ何も表示されません。
もし問題なければ、WP Discourse プラグインの「Logs」パネルに移動し、ログをダウンロードして PM で送ってください。ログには個人を特定できる情報や秘密情報は含まれていません。
ログの詳細や含まれる内容については、以下をご覧ください。
もちろん、すぐにお送りします。どこ宛てに送ればよいでしょうか?
meta.discourse.org のここでメッセージを送ってください。
私にメッセージを作成するにはこのリンクをクリック
メッセージを送信できません。
