שימור sessions משתמשים בעת מעבר בין hosts
סיכום מבוסס בינה מלאכותית
In a discussion about preserving user sessions during Discourse migrations between hosts, TallTrees reports that users are logged out after migration despite careful DNS simulation. Others, including ChrisBeach and riking, confirm similar issues. IAmGav suggests informing users they’ll need to re-login, but TallTrees warns this risks reduced engagement, password recovery issues, and zombie accounts. david identifies the root cause: session cookies are encrypted with a secret key stored in Redis, which is not included in backups. He proposes manually exporting the DISCOURSE_SECRET_KEY_BASE from the old server, setting it in app.yml on both old and new servers before migration, and rebuilding the app to preserve sessions. He cautions against sharing the key across instances for security reasons. TallTrees plans to test this in a sandbox and suggests documenting the process on Meta. david notes that including the key in backups would compromise security, as it would allow attackers to forge sessions. TallTrees adds that backups should also be encrypted (e.g., via GPG) to protect sensitive PM data. Stephen clarifies that Discourse’s “Personal Messages” aren’t private by default, though TallTrees argues users still expect confidentiality. david recommends Discourse Encrypt for truly private messages. TallTrees thanks david and confirms the solution works, expressing relief at being able to migrate without losing sessions.
Hi!
I’m preparing to migrate some Discourse instances to new hosting. The plan is to set the old site read-only, take a backup, move that across to the new hosting and restore while updating the DNS settings (on a short TTL). This process is all taken from guides here and around.
I’ve been doing some dry-runs on this, using a /etc/hosts file hack to simulate the DNS update (and with DNS over HTTPS disabled in the browser too). So far so good.
However, despite being careful to close the browser on the ‘source’ site, then only opening it after complete migration on the ‘destination’ site, it forgets that it was logged in.
Obviously I don’t want the site members to all be logged out over the migration. Where should I look or what am I missing here?
The user I’m currently testing has Admin and is using 2FA, and the discourse containers are behind Nginx which terminates SSL, if that makes a difference to the problem.
Thanks in advance for any pointers!
I’ve had this problem too and I’m keen to resolve it.
Any pointers appreciated.
I think I’m going to try creating some test accounts without 2FA in case that has anything to do with it - very few site members use 2FA, so that might be acceptable it it’s just those sessions that get lost.
Also I’ll check the source and destination servers are sync’d to NTP though they can’t be more than a few seconds off each other now I think.
Other than that, I guess there’s always the source code to try and figure out what goes into the authentication token and could be causing a problem… :grimacing:
Your best would be to inform your users about the change and that they would be logged out and need to sign in again.
Each server has their unique signature with the SSL in place.
It will be less of a headache to make the user sign in again, than trying to change server settings.
Just apologize for the inconvenience caused, but point out its for the better
Is that the case though?
How are session cookies affected by SSL “signatures” (especially when, in my case, the new and old hosts are using the same SSL certificate files, on the same domain name)?
While I have no problem apologizing to the members (:slightly_smiling_face:), I really want to avoid that scenario as I can see a couple of unfavorable side-effects:
  1. Members don’t log in again, and are less likely to participate in the forum in future
  2. Members forget their password and need help recovering their passwords
  3. Members forget their passwords and create new accounts, leaving lots of ‘zombie accounts’ on the forum and lost/confusing duplicate identities without User Notes or post history etc…
The SSL bit all works fine in front of Discourse (even with the hosts file hack), which if you think about it, must be the case otherwise load-balancers would have problems. As far as I’m aware, Discourse doesn’t even know about the SSL as it is terminated at Nginx in this setup.
I guess a different question is ‘is it possible to migrate a Discourse server to a new IP without logging everyone out?’ I had assumed it would be, but maybe that assumption was wrong… :frowning:
I know that I’ve definitely had forum sessions survive a backup & restore. I’m really not sure what’s going on here :frowning:
Session cookies are encrypted using a randomly generated secret key which, by default, is stored in redis. Redis data is not included in a backup so a new secret key is regenerated when you restore the site onto a new server.
You can manually set the secret key using an environment variable DISCOURSE_SECRET_KEY_BASE in your app.yml file. So you could try something like this to preserve sessions:
  1. On your existing server, enter the console and find the secret key from redis
    pry(main)> GlobalSetting.safe_secret_key_base
    => "5fb9dc98be368599e0a..."
  2. Add DISCOURSE_SECRET_KEY_BASE to the env: section of your app.yml on the old server, using the value you found in (1), and rebuild the app. In theory, if everything went right, Discourse should now use the value from the app.yml, and user sessions will persist. You can check the env variable is being used by running
    GlobalSetting.secret_key_base
  3. Make sure the app.yml on the new server has the same SECRET_KEY_BASE. When you restore the backup, the user sessions should persist
I haven’t tested that flow, so if you plan to use it for a production forum make sure to test it out first!
Side note: you absolutely should not share the secret key between multiple discourse instances. Possession of the secret key would allow someone to decrypt and modify their session cookie on a site, and could have very bad security consequences.
Excellent - this is something I shall try out on a sandbox instance. I’ll see if I can report back if it works or not :slight_smile:
Understood. I am now pondering whether there should be a feature request for an option to export this key in backups? To me, losing all the sessions on a site would seem like a ‘very bad thing’ to happen as there are a few thousand accounts on the site. Practicing the migration has shown this problem, but I guess if the machine or Docker instance were lost for some reason, the key would be lost too and we’d be facing the same loss of sessions.
Some note of this ‘feature’ on the migration topic might be good too: Move your Discourse Instance to a Different Server
It is a delicate balancing act between security and convenience.
At the moment if someone manages to steal a discourse backup, they have all the data on the forum. But they do not have the ability to log in to the live forum. Passwords are hashed, api keys are hashed, and session cookies are encrypted.
If we included the secret inside the backup, then anyone in possession of a backup could gain access to the live forum, and conduct phishing/fraud/etc.
Sounds great! Totally open to having a topic here on Meta explaining how to migrate from a redis secret key to an app.yml secret key. It could be linked from the ‘move to a different server’ topic.
The security of the default backups should also be improved too, in my humble opinion. While passwords and sessions may be hashed and protected, there could be a lot of other data in private messages and such which should still remain confidential. Particularly note that in our community forum we encourage people to use private messages to swap contact details and arrange sales or collections, rather than putting phone numbers and addresses in public places.
The approach I’m taking to backups is to enter the instance, generate a backup, then immediately encrypt it with a public key using gpg. This renders the backup useless to anyone that doesn’t have the corresponding private key, which I store off the server and protected by a passphrase.
That said, if the secret key for sessions doesn’t change, it only need to be backed up once, so a simple procedure for that is all that’s needed - and hopefully is what you’ve outlined above.
I’ll give it a go and see if I can create that topic for you :slight_smile:
Very helpful @david, thanks!
Discourse doesn’t offer private messages, the feature is called Personal Messages. The distinction is very important, there’s no suggestion of privacy.
Admins can already read every PM on the site unless encryption is in use.
Good point. But it doesn’t change the fact that members may use PM’s to exchange personal details or things that they wish not to be in the public domain. Protecting this data as far as is reasonable is therefore important.
Yes, we also have to trust the admins of every site we use, even on sites like ProtonMail.
Kind of off topic… but you might be interested in Discourse Encrypt (deprecated) for truly ‘private’ messages. Leaked/stolen backups of encrypted PMs would not be readable by an attacker.
(although, as you said, there is still an assumption that the admins are trusted)
@david - please can you check the following post and split and move to howto if okay? (I cannot create a topic there, oh and Akismet just hid the post so that needs fixing too :blush: )
@david - many many thanks for sorting that and the advice, I hope it helps others too - it’s certainly a relief for us to be able to migrate and keep the sessions :partying_face:
