AgentGod
(Agent God)
August 14, 2015, 6:53pm
1
Hi
after the last update I have strange problem in mobile view.
I have two forums and both are set to show the Categories on front page. In desktop it shows correctly but in mobile only the header is there. When I set it to show the latest or new posts it’s ok.
Regards
Stephen
(Stephen)
August 14, 2015, 7:14pm
There was an issue with an earlier build which caused this, it might be the same problem?
The categories tab on mobile is broken. That is the issue. It happens on the meta also.
Visit on mobile, select categories.
The solution was to update again.
AgentGod
(Agent God)
August 14, 2015, 7:18pm
3
I think, previously it was OK for me.
At the moment I am with v1.4.0.beta9 +7 and I have that problem.
I have checked on meta and it’s OK.
Hey Agent,
They updated the JS and it fixed the issue for me. Seems that we had the same problem.
My site is running +53.
AgentGod
(Agent God)
August 14, 2015, 7:40pm
5
I have just found another bug.
I can’t save the setting when I remove “flag sockpuppets”
zogstrip
(Régis Hanol)
August 14, 2015, 8:36pm
6
You definitely need to update to the latest version. All these bugs are fixed.
