Lew_Grothe reported issues rebuilding a self-hosted Discourse instance after removing a non-supported plugin, encountering a SIGTERM error and “FAILED TO COMMIT” during the process. pfaffman initially suspected insufficient RAM or swap, but after Lew_Grothe confirmed 2GB RAM + 2GB swap and later upgraded to 4GB, the error persisted. pfaffman noted the SIGTERM suggested manual interruption, but Lew_Grothe clarified it occurred automatically during the build. pfaffman speculated the commit error might be benign, while Lew_Grothe considered a GitHub-related pipeline issue. pfaffman suggested an outdated OS or filesystem permissions might be the culprit and recommended a fresh install with backup restore, referencing a migration guide. Lew_Grothe resolved the issue by deploying a new droplet, performing a fresh install, and restoring from backup. pfaffman later theorized the root cause might have been expired HTTPS certificates or a broken keychain, which an OS upgrade could fix — though he still prefers a clean reinstall for reliability.
I’ve got a problem rebuilding a test domain (self hosted - been running for ~7 years with infrequent updates but was running with latest release up until this week).
I had problems with a non-supported plugin which I’ve now removed and I think that may have scrogged something in the database or configuration. The error I get at completion is:
2024-04-25 01:07:42.098 UTC [34] LOG: received fast shutdown request
I, [2024-04-25T01:07:42.099067 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 96
96:signal-handler (1714007262) Received SIGTERM scheduling shutdown...
2024-04-25 01:07:42.105 UTC [34] LOG: aborting any active transactions
2024-04-25 01:07:42.121 UTC [34] LOG: background worker "logical replication launcher" (PID 49) exited with exit code 1
96:M 25 Apr 2024 01:07:42.121 # User requested shutdown...
96:M 25 Apr 2024 01:07:42.122 * Saving the final RDB snapshot before exiting.
2024-04-25 01:07:42.133 UTC [44] LOG: shutting down
96:M 25 Apr 2024 01:07:42.177 * DB saved on disk
96:M 25 Apr 2024 01:07:42.178 # Redis is now ready to exit, bye bye...
2024-04-25 01:07:42.195 UTC [34] LOG: database system is shut down
Error response from daemon: invalid JSON: got EOF while reading request body
FAILED TO COMMIT cbaab1290466a63d0a77f5f1e0894b0da632204e63472416674b7fab9ae53b41
I’ve scanned the rest of the log and the only additional errors I see are accounted for as “not important” on other posts here.
Any suggestions as to what to do next?
I think I might be left at this point to do a fresh install and then attempt a restore from backup but would appreciate any hints as to what might actually be going on…
I was - I’d forgotten we’d been fiddling with the WordPress instance that’s also running on that droplet so we’re deffinitely using some swap space. Probably need to grow that VPS anyway…
Yes.
I grep’d the log and didn’t see that error.
I had the bright idea of doing a reboot of the VPS before trying again. Presuming that fails, I’ll grow the droplet and try again.
no - I presume there’s something in one of the scripts in the build process - it’s the same way I’ve built it for years (ssh into a couple of sessions - one watching the other…) - all of them since it started failling have a sigterm in (I presume) that same place in the script which seems to close the app that something is reading from…
Is there something in the launcher script that does something back to GitHub? Would explain the error if there’s some sort of metric they track by a commit - if that’s in a shell pipeline (eg. Curl or such), would also explain closed pipe error.
Rather than my attempting to debug what’s going on with launcher, I think the easiest thing for me would be to try to do a new install and restore.
Happy to accept suggestions if you have any ideas…
