rriemann
(Robert)
1
I want to add this link here: https://www.google.de/maps/place/Laureline’s+Corner/@45.7691847,4.8353492,19z/data=!4m5!3m4!1s0x0:0xcc75bbd0365fd4c4!8m2!3d45.7693561!4d4.835522
As you can there, there is an Apostrophe in the URL -> ' <-
When I now use the [linktext](link url) syntax, e.g. using Ctrl+K to acess the dialog, I get this here:
Map
So far, it works.
Now, I want to add This link within parenthesis: ([linktext](link url)).
Then, it does not work anymore:
(Map)
As you can see, the closing parenthesis is not shown.
You can fix this problem by removing the apostrophe, but then the link is a different one.
إعجاب واحد (1)
This is a Markdown problem, in general. My suggestion is to do the following:
[linktext][1]
[1]: https://www.google.de/maps/place/Laureline's+Corner/@45.7691847,4.8353492,19z/data=!4m5!3m4!1s0x0:0xcc75bbd0365fd4c4!8m2!3d45.7693561!4d4.835522
Can also be applied to links with parenthesis.
إعجابَين (2)
rriemann
(Robert)
3
Where is the upstream markdown bug tracker? It is still an unattended behaviour and should be fixed somewhere in my humble opinion.
pfaffman
(Jay Pfaffman)
4
Shouldn’t the apostrophe be URL encoded?
rriemann
(Robert)
5
This is a good question. I clicked on Share on Google Maps and copy’n’pasted
the link including the apostrophe.
mcwumbly
(Dave McClure)
6
Eventually Discourse will use some implementation of CommonMark.
Try it here:
And discuss here:
6 إعجابات
rriemann
(Robert)
7
I could not reproduce this problem with commonmark Dingus.
5 إعجابات
sam
(Sam Saffron)
8
Fixed now with our new CommonMark engine, see: CommonMark testing started here! - #2
3 إعجابات
