URLs in parenthesis do not turn into links
A discussion emerged about URLs in parentheses not turning into links in Discourse. swisspol mentioned this issue, thinking it might be a regression. However, Mittineague pointed out that it’s not a regression, but rather incorrect syntax, as the correct way to link a URL is by using the Markdown link syntax.
Mittineague suggested adding spaces around the URL in parentheses ( http://www.google.com ) to make it linkable. tgxworld countered that this might not be incorrect syntax, citing an example from GitHub. However, Mittineague clarified that Discourse uses a different flavor of Markdown than GitHub.
The conversation continued with tgxworld wondering if the behavior is intentional, and Mittineague agreeing that there’s no advantage to not turning URLs into links when wrapped in parentheses. codinghorror suggested providing extra hints to make the URLs linkable, and sam mentioned that the autolinker in Discourse has its flaws and might not be a feature worth shipping.
The discussion concluded with tgxworld questioning whether the behavior is a bug or a feature, and Mittineague expressing frustration with the complexity of the autolinker regex.
v1.4.0.beta3 +76
If you enter URLs in parenthesis, they don’t turn into links:
like this (http://www.apple.com)
I wonder if that’s a regression as I thought this was working maybe 1 or 2 months ago.
1 Curtiu
No regression, that’s incorrect syntax
Try like shown here
Ah, I didn’t think it would be interpreted as the parenthesis of the markdown link syntax, in which case yes, the brackets would be missing.
That’s too bad as surely I’m not going to be the only to want / attempt to naively put a URL in parenthesis (for reference, I am aware of the markdown link syntax which I use, but sometimes I appreciate being able to just paste a URL and having it works as-is).
A plain URL will become “linkified” but if you want it in parentheses there needs to be spaces
Hmm I don’t think it is incorrect syntax. See below for the example on Github.
Maybe so, but there are different “flavors” of MarkDown. (eg. CommonMark :wink:)
Hint: Discourse does not use the same as Github uses
2 Curtiram
Thanks for clarifying :smile: I wonder if the above is intentional though since I don’t see any advantages of not turning URLs into links if you wrap them in ().
Neither do I, just the way it is I guess. Same thing when they’re in quotation marks
"http://www.youtube.com"
“http://www.youtube.com”
1 Curtiu
You can always provide extra hints, e.g.
(http://example.com)
(<http://example.com>)
Turning “raw” links into actual links is not part of Markdown proper. In Markdown, typing a raw link does nothing.
6 Curtiram
Also, our autolinker is one of the more annoying regexes we ship, and it has plenty holes https://github.com/discourse/discourse/blob/master/app/assets/javascripts/discourse/dialects/autolink_dialect.js
2 Curtiram
Hmm is it a feature that we would want to ship with autolink since we don’t classify it as a bug?
I’ll say. Anytime I see that many “nots” I can’t help but cringe a little
[^`!()\[\]{};:'".,<>?«»“”‘’\s]
and that’s only a small bit of it!
2 Curtiram
