Propose to add an ability to highlight the XML Schema Definitions (XSD)
2 לייקים
I’m pretty sure syntax highlighter is this one:
which a separate package with separate maintainers.
Anyway, their docs say use “html or xml” for XSD.
In Discourse, that would mean naming it on the code fence:
```xml
    <xs:complexType name="argumentType" abstract="true" mixed="false">
	<xs:complexContent>
	    <xs:extension base="argumentType" />
	</xs:complexContent>
    </xs:complexType>
        <xs:complexContent>
    </xs:complexType>
7 לייקים
It would be nice to make it working for the GitHub oneboxes.
