I just created a brand new Discourse so I’m still going through the settings. As of right now, I can’t view my Discourse unless I’m logged in. I’m not seeing the same settings options that others are posting as a solution to this problem. I’d like users to be able to view/read my Discourse without creating account. Any help would be great!
In your settings, search for login required and disable the checkbox.
login required: Require authentication to read content on this site, disallow anonymous access.
Is this a standard install, or are you using discourse.org’s “basic” hosting, which offers:
So I’m on the 14 day trial period and plan was to stay on the $25 per month plan. Would that be the reason I’m not seeing the option?
Hi @ahunziker. ![]()
As Jay pointed out, the Basic plan is for private communities, so you won’t be able to host a public site on that plan. That would be a Standard plan.
