Citeren van Markdown-lijst van Discourse-citaten mislukt
The user rokejulianlockhart is reporting an issue with quoting Markdown lists of Discourse quotes. When they try to quote a post, it breaks halfway and doesn’t quote everything, despite selecting all the text. They provided an example of the issue, which involves quoting multiple posts with Markdown lists and images. The user is looking for a way to quote the entire post without it breaking, and they suspect it might be related to the formatting of the quoted text.
  1. Issue
    When trying to quote
    Can I copy an image from #Spectacle in a format different to the default? - #5 by rokejulianlockhart - Help - KDE Discuss
    tested at https://try.discourse.org/t/https-discuss-kde-org-t-can-i-copy-an-image-from-spectacle-in-a-format-different-to-the-default-6611-5-u-rokejulianlockhart/1469?u=rokejulianlockhart for the sake of posterity,
    occurs – it doesn’t quote everything, despite me selecting everything. Rather, it breaks halfway.
  2. Example
    @tubbadu, per:
    …all I want to do is be able to save a captured image’s content (I believe that’s what you refer to by “pixmap”, certainly not its path) in a format different to the default configured in #Spectacle’s Preferences page without having to save it as a different file type first (after which it indeed allows me to do so, albeit solely as the file type I saved it as last).
    [quote="tubbadu, post:4, topic:6611, full:true"]
    I don’t think I understand: when you copy the image, do you mean to copy “file://path/tofile.tiff” or to copy the pixmap to clipboard?
    [/quote]
    @tubbadu, per:
    0.	[quote="rokejulianlockhart, post:1, topic:6611"]
    	By default, #spectacle::tag saves my images as `.tiff`.
    	[/quote]
    	However, I frequently want to copy these screenshots as `.png` files.
    	[/quote]
    	I don’t seem to be able to do this without first having to save the image as `.png`, after which I’m able to use “Copy” to copy it to the clipboard as whatever I saved it as (`.png`).
    	[/quote]
    …all I want to do is be able to save a captured image's *content* (I believe that's what you refer to by “pixmap”, certainly not its path) in a format different to the default configured in #Spectacle's Preferences page without having to save it as a different file type first (after which it indeed allows me to do so, albeit solely as the file type I saved it as last).
