Pouvez-vous vérifier les journaux de reconstruction ?
x86_64 arch detected.
fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20230703-0055: Pulling from discourse/base
Digest: sha256:a943db5c56ee8b2025ec550b42fe12ecfa63990d428f43ba8358ca3632b5335f
Status: Image is up to date for discourse/base:2.0.20230703-0055
docker.io/discourse/base:2.0.20230703-0055
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2024-06-07T19:54:40.117648 #1] INFO -- : Reading from stdin
I, [2024-06-07T19:54:40.121975 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2024-06-07T19:54:40.180322 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2024-06-07T19:54:40.180450 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2024-06-07T19:54:40.182597 #1] INFO -- :
I, [2024-06-07T19:54:40.182766 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2024-06-07T19:54:40.184586 #1] INFO -- :
I, [2024-06-07T19:54:40.184716 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2024-06-07T19:54:40.186267 #1] INFO -- :
I, [2024-06-07T19:54:40.186393 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2024-06-07T19:54:40.188213 #1] INFO -- :
I, [2024-06-07T19:54:40.188364 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2024-06-07T19:54:40.202872 #1] INFO -- :
I, [2024-06-07T19:54:40.203003 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2024/06/07 19:54:40 socat[19] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2024-06-07T19:54:40.239340 #1] INFO -- :
I, [2024-06-07T19:54:40.239471 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2024-06-07T19:54:40.241738 #1] INFO -- :
I, [2024-06-07T19:54:40.241862 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2024-06-07T19:54:40.244044 #1] INFO -- :
I, [2024-06-07T19:54:40.244160 #1] INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-06-07T19:54:40.246016 #1] INFO -- :
I, [2024-06-07T19:54:40.246229 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2024-06-07T19:54:40.248009 #1] INFO -- :
I, [2024-06-07T19:54:40.251919 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2024-06-07T19:54:40.255616 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2024-06-07T19:54:40.259315 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2024-06-07T19:54:40.281707 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2024-06-07T19:54:40.281977 #1] INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2024-06-07T19:54:40.587614 #1] INFO -- :
I, [2024-06-07T19:54:40.587721 #1] INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2024-06-07T19:54:40.589492 #1] INFO -- :
I, [2024-06-07T19:54:40.589541 #1] INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2024-06-07T19:54:40.799426 #1] INFO -- :
I, [2024-06-07T19:54:40.799528 #1] INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2024-06-07T19:54:40.801475 #1] INFO -- :
I, [2024-06-07T19:54:40.801652 #1] INFO -- : > /root/upgrade_postgres
I, [2024-06-07T19:54:40.817063 #1] INFO -- :
I, [2024-06-07T19:54:40.817197 #1] INFO -- : > rm /root/upgrade_postgres
I, [2024-06-07T19:54:40.818897 #1] INFO -- :
I, [2024-06-07T19:54:40.825870 #1] INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.826464 #1] INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.827327 #1] INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.827948 #1] INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.828546 #1] INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.829199 #1] INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.829815 #1] INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2024-06-07T19:54:40.875180 #1] INFO -- :
I, [2024-06-07T19:54:40.875428 #1] INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.875775 #1] INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.876505 #1] INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2024-06-07T19:54:40.884820 #1] INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres peer in /etc/postgresql/13/main/pg_hba.conf
I, [2024-06-07T19:54:40.885131 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-06-07T19:54:40.885870 #1] INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2024-06-07T19:54:40.886430 #1] INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2024-06-07T19:54:40.887648 #1] INFO -- : > sleep 5
2024-06-07 19:54:40.919 UTC [42] LOG: starting PostgreSQL 13.11 (Debian 13.11-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2024-06-07 19:54:40.919 UTC [42] LOG: listening on IPv4 address "0.0.0.0", port 5432
2024-06-07 19:54:40.919 UTC [42] LOG: listening on IPv6 address "::", port 5432
2024-06-07 19:54:40.921 UTC [42] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2024-06-07 19:54:40.924 UTC [45] LOG: database system was shut down at 2024-06-07 19:54:32 UTC
2024-06-07 19:54:40.928 UTC [42] LOG: database system is ready to accept connections
I, [2024-06-07T19:54:45.889456 #1] INFO -- :
I, [2024-06-07T19:54:45.889784 #1] INFO -- : > su postgres -c 'createdb discourse' || true
2024-06-07 19:54:46.139 UTC [55] postgres@postgres ERROR: database "discourse" already exists
2024-06-07 19:54:46.139 UTC [55] postgres@postgres STATEMENT: CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR: database "discourse" already exists
I, [2024-06-07T19:54:46.141019 #1] INFO -- :
I, [2024-06-07T19:54:46.141248 #1] INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2024-06-07 19:54:46.220 UTC [59] postgres@discourse ERROR: role "discourse" already exists
2024-06-07 19:54:46.220 UTC [59] postgres@discourse STATEMENT: create user discourse;
I, [2024-06-07T19:54:46.221446 #1] INFO -- :
I, [2024-06-07T19:54:46.221633 #1] INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2024-06-07T19:54:46.268526 #1] INFO -- : GRANT
I, [2024-06-07T19:54:46.268701 #1] INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2024-06-07T19:54:46.321919 #1] INFO -- : ALTER SCHEMA
I, [2024-06-07T19:54:46.322079 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE: extension "hstore" already exists, skipping
I, [2024-06-07T19:54:46.418689 #1] INFO -- : CREATE EXTENSION
I, [2024-06-07T19:54:46.418871 #1] INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE: extension "pg_trgm" already exists, skipping
I, [2024-06-07T19:54:46.464568 #1] INFO -- : CREATE EXTENSION
I, [2024-06-07T19:54:46.464722 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2024-06-07T19:54:46.525751 #1] INFO -- : CREATE EXTENSION
I, [2024-06-07T19:54:46.525909 #1] INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2024-06-07T19:54:46.571484 #1] INFO -- : CREATE EXTENSION
I, [2024-06-07T19:54:46.571682 #1] INFO -- : > sudo -u postgres psql discourse
I, [2024-06-07T19:54:46.583469 #1] INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2024-06-07T19:54:46.723837 #1] INFO -- : File > /var/lib/postgresql/take-database-backup chmod: +x chown: postgres:postgres
I, [2024-06-07T19:54:46.726190 #1] INFO -- : File > /var/spool/cron/crontabs/postgres chmod: chown:
I, [2024-06-07T19:54:46.726274 #1] INFO -- : > echo postgres installed!
I, [2024-06-07T19:54:46.727875 #1] INFO -- : postgres installed!
I, [2024-06-07T19:54:46.731856 #1] INFO -- : File > /etc/service/redis/run chmod: +x chown:
I, [2024-06-07T19:54:46.735623 #1] INFO -- : File > /etc/service/redis/log/run chmod: +x chown:
I, [2024-06-07T19:54:46.739424 #1] INFO -- : File > /etc/runit/3.d/10-redis chmod: +x chown:
I, [2024-06-07T19:54:46.746268 #1] INFO -- : Replacing daemonize yes with in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.746725 #1] INFO -- : Replacing (?-mix:^pidfile.*$) with in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.747551 #1] INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2024-06-07T19:54:46.749781 #1] INFO -- :
I, [2024-06-07T19:54:46.750095 #1] INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.750498 #1] INFO -- : Replacing (?-mix:^bind .*$) with in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.751539 #1] INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.752603 #1] INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.753605 #1] INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2024-06-07T19:54:46.754609 #1] INFO -- : > echo redis installed
I, [2024-06-07T19:54:46.756205 #1] INFO -- : redis installed
I, [2024-06-07T19:54:46.756327 #1] INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2024-06-07T19:54:46.759243 #1] INFO -- : logfile ""
I, [2024-06-07T19:54:46.759408 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-06-07T19:54:46.760587 #1] INFO -- : > sleep 10
103:C 07 Jun 2024 19:54:46.766 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
103:C 07 Jun 2024 19:54:46.766 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=103, just started
103:C 07 Jun 2024 19:54:46.766 # Configuration loaded
103:M 07 Jun 2024 19:54:46.766 * monotonic clock: POSIX clock_gettime
103:M 07 Jun 2024 19:54:46.767 * Running mode=standalone, port=6379.
103:M 07 Jun 2024 19:54:46.767 # Server initialized
103:M 07 Jun 2024 19:54:46.767 * Loading RDB produced by version 7.0.7
103:M 07 Jun 2024 19:54:46.767 * RDB age 15 seconds
103:M 07 Jun 2024 19:54:46.767 * RDB memory usage when created 6.04 Mb
103:M 07 Jun 2024 19:54:46.775 * Done loading RDB, keys loaded: 1191, keys expired: 0.
103:M 07 Jun 2024 19:54:46.775 * DB loaded from disk: 0.008 seconds
103:M 07 Jun 2024 19:54:46.775 * Ready to accept connections
I, [2024-06-07T19:54:56.762421 #1] INFO -- :
I, [2024-06-07T19:54:56.762635 #1] INFO -- : > thpoff echo "thpoff is installed!"
I, [2024-06-07T19:54:56.766005 #1] INFO -- : thpoff is installed!
I, [2024-06-07T19:54:56.766206 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2024-06-07T19:54:56.835441 #1] INFO -- :
I, [2024-06-07T19:54:56.835589 #1] INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2024-06-07T19:54:56.903998 #1] INFO -- :
I, [2024-06-07T19:54:56.904127 #1] INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2024-06-07T19:54:56.972425 #1] INFO -- :
I, [2024-06-07T19:54:56.972533 #1] INFO -- : > rm -f /etc/cron.d/anacron
I, [2024-06-07T19:54:56.974547 #1] INFO -- :
I, [2024-06-07T19:54:56.976944 #1] INFO -- : File > /etc/cron.d/anacron chmod: chown:
I, [2024-06-07T19:54:56.981124 #1] INFO -- : File > /etc/runit/1.d/copy-env chmod: +x chown:
I, [2024-06-07T19:54:56.985081 #1] INFO -- : File > /etc/service/unicorn/run chmod: +x chown:
I, [2024-06-07T19:54:56.998263 #1] INFO -- : File > /etc/service/nginx/run chmod: +x chown:
I, [2024-06-07T19:54:57.002183 #1] INFO -- : File > /etc/runit/3.d/01-nginx chmod: +x chown:
I, [2024-06-07T19:54:57.010445 #1] INFO -- : File > /etc/runit/3.d/02-unicorn chmod: +x chown:
I, [2024-06-07T19:54:57.010551 #1] INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2024-06-07T19:54:57.011298 #1] INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2024-06-07T19:54:57.013092 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
130:C 07 Jun 2024 19:54:57.018 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
130:C 07 Jun 2024 19:54:57.018 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=130, just started
130:C 07 Jun 2024 19:54:57.018 # Configuration loaded
130:M 07 Jun 2024 19:54:57.018 * monotonic clock: POSIX clock_gettime
130:M 07 Jun 2024 19:54:57.019 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
130:M 07 Jun 2024 19:54:57.019 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33396/33396), done.
I, [2024-06-07T19:55:04.427724 #1] INFO -- : HEAD is now at 3f1024de7 DEV: Refactor DM channel creation into new service pattern (#22144)
I, [2024-06-07T19:55:04.427843 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2024-06-07T19:55:04.531767 #1] INFO -- :
I, [2024-06-07T19:55:04.531874 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
git remote set-branches --add origin main
git remote set-branches origin tests-passed
git fetch --depth 1 origin tests-passed
else
git fetch --tags --prune-tags --prune --force origin
fi
From https://github.com/discourse/discourse
- [deleted] (none) -> origin/0-bulk
- [deleted] (none) -> origin/0-drop-raw-email
- [deleted] (none) -> origin/0-drop-sk-test
- [deleted] (none) -> origin/0-followup
- [deleted] (none) -> origin/a-e-c
- [deleted] (none) -> origin/a-e-c-d
- [deleted] (none) -> origin/a-smokes-test
- [deleted] (none) -> origin/a11y-sidebar-contrast
- [deleted] (none) -> origin/activation-modals-update
- [deleted] (none) -> origin/add-ignored-to-mod-activity
- [deleted] (none) -> origin/add-timeout-for-cache-download
- [deleted] (none) -> origin/add_users_groups_to_community_section
- [deleted] (none) -> origin/admin-component-codemod
- [deleted] (none) -> origin/allow-category-moderators-to-move-topics-to-category
- [deleted] (none) -> origin/alt-multi-select
- [deleted] (none) -> origin/angle-bracket-codemod-run
- [deleted] (none) -> origin/api-safety
- [deleted] (none) -> origin/avatar-uploader-test-martin
- [deleted] (none) -> origin/badge-issue
- [deleted] (none) -> origin/category-serialize-extension
- [deleted] (none) -> origin/chat-drawer-unautofocus
- [deleted] (none) -> origin/chat-messages-streaming
- [deleted] (none) -> origin/chat-notices
- [deleted] (none) -> origin/chat-permission
- [deleted] (none) -> origin/chat-thread-messages-basic
- [deleted] (none) -> origin/chat-thread-panel-initial-skeleton
- [deleted] (none) -> origin/chat-thread-panel-sketch
- [deleted] (none) -> origin/chat/streaming
- [deleted] (none) -> origin/chatable-index-werk
- [deleted] (none) -> origin/dependabot/bundler/omniauth-2.1.1
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/babel-plugin-ember-template-compilation-2.0.2
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/ember-on-resize-modifier-2.0.2
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.4.0
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.2.1
- [deleted] (none) -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.3.0
- [deleted] (none) -> origin/dev-api-table-buttons
- [deleted] (none) -> origin/dev-remove-quick-access-profile
- [deleted] (none) -> origin/dev/add-plugin-api-for-additional-pretty-text-options
- [deleted] (none) -> origin/dev/allow-hiding-chat-secondary-buttons
- [deleted] (none) -> origin/dev/chat-message-actions-experiments
- [deleted] (none) -> origin/dev/chat-transcript-system-spec-2
- [deleted] (none) -> origin/dev/disable-threadsafe-capybara
- [deleted] (none) -> origin/dev/disable-threadsafe-capybara-2
- [deleted] (none) -> origin/dev/experimental-refactoring
- [deleted] (none) -> origin/dev/extra-fields-saving-user-preferences
- [deleted] (none) -> origin/dev/extract-methods-into-channel-model
- [deleted] (none) -> origin/dev/flexible-quote-button
- [deleted] (none) -> origin/dev/hashtag-system-spec-1
- [deleted] (none) -> origin/dev/hashtag-system-spec-2
- [deleted] (none) -> origin/dev/hashtag-system-spec-3
- [deleted] (none) -> origin/dev/hashtag-system-spec-4
- [deleted] (none) -> origin/dev/latest-rails-sys-spec-lock-branch
- [deleted] (none) -> origin/dev/make-sure-we-stream-data-to-csv-files-when-running-exports
- [deleted] (none) -> origin/dev/mention-notifications-expander
- [deleted] (none) -> origin/dev/move-chat-user-count-update-to-ensure-consistency
- [deleted] (none) -> origin/dev/refactor-chat-notifier
- [deleted] (none) -> origin/dev/refactor-create-dm-channel-into-service
- [deleted] (none) -> origin/dev/refactor-dm-channel-creator-into-service
- [deleted] (none) -> origin/dev/user-auto-group-fabricator
- [deleted] (none) -> origin/dev/user-that-cant-chat-shouldnt-be-able-to-join-channel
- [deleted] (none) -> origin/dev_update_diffhtml
- [deleted] (none) -> origin/dismiss-modals-update
- [deleted] (none) -> origin/ember-this-fallback
- [deleted] (none) -> origin/emoji-update-production
- [deleted] (none) -> origin/esbuild
- [deleted] (none) -> origin/experimental-refactoring
- [deleted] (none) -> origin/feature-route-control
- [deleted] (none) -> origin/feature/change-watched-word-uploader-to-use-uppy
- [deleted] (none) -> origin/feature/chat-thread-client-skeleton
- [deleted] (none) -> origin/feature/chat-thread-messages-part-1
- [deleted] (none) -> origin/feature/dont-feed-the-trolls
- [deleted] (none) -> origin/feature/go-to-last-unread-post-topic-bookmark
- [deleted] (none) -> origin/feature/hashtag-no-icon-cook
- [deleted] (none) -> origin/feature/markdown-block-changes-chat
- [deleted] (none) -> origin/feature/separate-topic-bookmarks-into-own-distinct-pattern
- [deleted] (none) -> origin/feature/status-on-mentions-on-updated-chat-messages
- [deleted] (none) -> origin/feature/thread-list-button-unread-count
- [deleted] (none) -> origin/feature/thread-list-button-unread-counter-initial
- [deleted] (none) -> origin/feature/tracking-unread-thread-in-sidebar
- [deleted] (none) -> origin/feature/update-translations-block-prefs
- [deleted] (none) -> origin/feature/watched-word-groups
- [deleted] (none) -> origin/feature_boostrap_mode_usertip
- [deleted] (none) -> origin/feature_bootstrap_mode
- [deleted] (none) -> origin/feature_bootstrap_mode_tooltip
- [deleted] (none) -> origin/feature_hide_user_tips
- [deleted] (none) -> origin/feature_user_tips_backfill
- [deleted] (none) -> origin/fix-intercept-with-target
- [deleted] (none) -> origin/fix-mobile-share
- [deleted] (none) -> origin/fix-select-kit-click-outside-regression
- [deleted] (none) -> origin/fix-tag-and-category-routing
- [deleted] (none) -> origin/fix-tests
- [deleted] (none) -> origin/fix-tests-passed
- [deleted] (none) -> origin/fix/chat-threading-no-echo-with-indicator
- [deleted] (none) -> origin/fix/multi-tag-search
- [deleted] (none) -> origin/fix/update-username-in-new-quote-format
- [deleted] (none) -> origin/fix_flaky_test
- [deleted] (none) -> origin/fix_media_elements
- [deleted] (none) -> origin/fix_url_welcome
- [deleted] (none) -> origin/form-template-modal
- [deleted] (none) -> origin/fullscreen-modals-update
- [deleted] (none) -> origin/generic-import
- [deleted] (none) -> origin/generic-import-clean
- [deleted] (none) -> origin/generic-import-cxl
- [deleted] (none) -> origin/generic-import-v2
- [deleted] (none) -> origin/generic-import-v3
- [deleted] (none) -> origin/glimmer-lightbox
- [deleted] (none) -> origin/group-add-members-modal-upgrade
- [deleted] (none) -> origin/group-directory-cleanup
- [deleted] (none) -> origin/headless-new
- [deleted] (none) -> origin/hide-header-and-sidebar
- [deleted] (none) -> origin/issue/allow-ensure-cors-to-add-more-than-one-rule
- [deleted] (none) -> origin/issue/fix-forwarded-email-group-inbox-cc
- [deleted] (none) -> origin/issue/font-loading-wizard-style
- [deleted] (none) -> origin/jancernik-replace-lazy-yt
- [deleted] (none) -> origin/labeler
- [deleted] (none) -> origin/large-notification-table
- [deleted] (none) -> origin/loading-slider-integration
- [deleted] (none) -> origin/loic-max-size-for-text-columns
- [deleted] (none) -> origin/loic-max-size-for-text-columns-chat-plugin
- [deleted] (none) -> origin/loic-max-size-for-text-columns-poll-plugin
- [deleted] (none) -> origin/loic-migrate-chat-message-creator-to-a-service
- [deleted] (none) -> origin/loic-n+1-gem
- [deleted] (none) -> origin/loic-refactor-user-email-job-as-class
- [deleted] (none) -> origin/loic-use-ar-enums-posts
- [deleted] (none) -> origin/mobile-categories-refactor
- [deleted] (none) -> origin/mobile-component-templates
- [deleted] (none) -> origin/modal-named-outlet
- [deleted] (none) -> origin/poll-plugin-update
- [deleted] (none) -> origin/poll-refactor
- [deleted] (none) -> origin/pr/20421
- [deleted] (none) -> origin/pr/21684
- [deleted] (none) -> origin/pwa-offline-indicator
- [deleted] (none) -> origin/rails-6.x-update
- [deleted] (none) -> origin/rebake-quotes
- [deleted] (none) -> origin/reply-where-position
- [deleted] (none) -> origin/revert-unaccent
- [deleted] (none) -> origin/ruby-deprecate-test
- [deleted] (none) -> origin/scroll-padding-top-take2
- [deleted] (none) -> origin/search_refactor
- [deleted] (none) -> origin/second-factor-add-security-key-modal-upgrade
- [deleted] (none) -> origin/second-factor-add-totp-modal-upgrade
- [deleted] (none) -> origin/second-factor-backup-edit-modal-upgrade
- [deleted] (none) -> origin/second-factor-edit-security-key-modal-upgrade
- [deleted] (none) -> origin/separate-chat-system-tests
- [deleted] (none) -> origin/serializer_api_changes
- [deleted] (none) -> origin/share-topic-modal
- [deleted] (none) -> origin/slack_import
- [deleted] (none) -> origin/test_message_bus_change
- [deleted] (none) -> origin/tests-passed-broken
- [deleted] (none) -> origin/tiktok-normalizing
- [deleted] (none) -> origin/topic-list-refactor
- [deleted] (none) -> origin/use-loofah-html5-frag
- [deleted] (none) -> origin/user-preferences-spec
- [deleted] (none) -> origin/ux-ac-user-metadata-alignment
- [deleted] (none) -> origin/watched-words-link
3f1024de7..c13f64d35 main -> origin/main
* [new branch] 0-a-fix-perf-watched-words -> origin/0-a-fix-perf-watched-words
* [new branch] 0-a-skf-gjs -> origin/0-a-skf-gjs
* [new branch] 0-app-events-revolution -> origin/0-app-events-revolution
* [new branch] 0-ember-bump-fix-modal -> origin/0-ember-bump-fix-modal
* [new branch] 0-extend-native -> origin/0-extend-native
* [new branch] 0-fast-edit-end -> origin/0-fast-edit-end
* [new branch] 0-fix-perf-watched-words -> origin/0-fix-perf-watched-words
* [new branch] 0-polls-still -> origin/0-polls-still
* [new branch] 0-rename-details -> origin/0-rename-details
* [new branch] 0-simpler-placeholder -> origin/0-simpler-placeholder
* [new branch] 0-store-bump -> origin/0-store-bump
* [new branch] 0-tooltip -> origin/0-tooltip
* [new branch] 0-user-status -> origin/0-user-status
bb2c5a053..ed8432c32 a-dejq-click -> origin/a-dejq-click
* [new branch] add-message-builder-modifier -> origin/add-message-builder-modifier
* [new branch] add-message-builder-modifier-3 -> origin/add-message-builder-modifier-3
* [new branch] add-signal-to-notifications-template -> origin/add-signal-to-notifications-template
* [new branch] add_mechanism_to_redeliver_all_webhook_events -> origin/add_mechanism_to_redeliver_all_webhook_events
* [new branch] after-post-outlet -> origin/after-post-outlet
* [new branch] allow-overriding-sidebar-my-posts-icon -> origin/allow-overriding-sidebar-my-posts-icon
* [new branch] allow-staff-to-tag -> origin/allow-staff-to-tag
* [new branch] array-custom-field-order -> origin/array-custom-field-order
* [new branch] asciinema-iframe -> origin/asciinema-iframe
* [new branch] async-category-link -> origin/async-category-link
* [new branch] bump-eslint-config -> origin/bump-eslint-config
* [new branch] carsick-patch-1 -> origin/carsick-patch-1
* [new branch] categories-modal-fix -> origin/categories-modal-fix
* [new branch] category_definition -> origin/category_definition
* [new branch] chat-github-onebox -> origin/chat-github-onebox
* [new branch] chat/direct-messages -> origin/chat/direct-messages
* [new branch] chat/experiment-swie-cancel -> origin/chat/experiment-swie-cancel
* [new branch] coco/generic-importer -> origin/coco/generic-importer
* [new branch] custom-field-store-cleanup -> origin/custom-field-store-cleanup
* [new branch] d-button-noautoclass -> origin/d-button-noautoclass
* [new branch] d-object -> origin/d-object
* [new branch] d-resource-experiment -> origin/d-resource-experiment
* [new branch] decorator-transforms-take-2 -> origin/decorator-transforms-take-2
* [new branch] demote-summarize-ai-button -> origin/demote-summarize-ai-button
* [new branch] dependabot/bundler/libv8-node-21.7.2.0 -> origin/dependabot/bundler/libv8-node-21.7.2.0
* [new branch] dependabot/bundler/mini_racer-0.12.0 -> origin/dependabot/bundler/mini_racer-0.12.0
* [new branch] dependabot/bundler/oauth2-2.0.9 -> origin/dependabot/bundler/oauth2-2.0.9
* [new branch] dependabot/bundler/omniauth-2.1.2 -> origin/dependabot/bundler/omniauth-2.1.2
* [new branch] dependabot/bundler/omniauth-facebook-10.0.0 -> origin/dependabot/bundler/omniauth-facebook-10.0.0
* [new branch] dependabot/bundler/omniauth-google-oauth2-1.1.2 -> origin/dependabot/bundler/omniauth-google-oauth2-1.1.2
* [new branch] dependabot/bundler/parallel_tests-4.4.0 -> origin/dependabot/bundler/parallel_tests-4.4.0
* [new branch] dependabot/bundler/sqlite3-2.0.2 -> origin/dependabot/bundler/sqlite3-2.0.2
* [new branch] dependabot/npm_and_yarn/ember-source-5.8.0 -> origin/dependabot/npm_and_yarn/ember-source-5.8.0
* [new branch] dependabot/npm_and_yarn/jsdoc-4.0.3 -> origin/dependabot/npm_and_yarn/jsdoc-4.0.3
* [new branch] dependabot/npm_and_yarn/markdown-it-14.1.0 -> origin/dependabot/npm_and_yarn/markdown-it-14.1.0
* [new branch] dev/add-a-reference-column-to-notifications -> origin/dev/add-a-reference-column-to-notifications
* [new branch] dev/always-load-problem-checks -> origin/dev/always-load-problem-checks
* [new branch] dev/deprecate-found-user-with-status-serializer -> origin/dev/deprecate-found-user-with-status-serializer
* [new branch] dev/drop-ignore-chat_channels_last_message_sent_at -> origin/dev/drop-ignore-chat_channels_last_message_sent_at
* [new branch] dev/ember-source-5.9.0-upgrade -> origin/dev/ember-source-5.9.0-upgrade
* [new branch] dev/fix-flaky-sidebar-category-test -> origin/dev/fix-flaky-sidebar-category-test
* [new branch] dev/incremental-imports-experiments-base -> origin/dev/incremental-imports-experiments-base
* [new branch] dev/incremental-imports-experiments-pgloaded -> origin/dev/incremental-imports-experiments-pgloaded
* [new branch] dev/incremental-imports-experiments-virtualpg -> origin/dev/incremental-imports-experiments-virtualpg
* [new branch] dev/notification-avatar-size-getter -> origin/dev/notification-avatar-size-getter
* [new branch] dev/promote-inline-checks-to-problem-checks -> origin/dev/promote-inline-checks-to-problem-checks
* [new branch] dev/promote-inline-problem-checks -> origin/dev/promote-inline-problem-checks
* [new branch] dev/proof-of-concept-rewriting-mentions-notification-logic -> origin/dev/proof-of-concept-rewriting-mentions-notification-logic
* [new branch] dev/refactor-uploads-importer -> origin/dev/refactor-uploads-importer
* [new branch] dev/rfc-value-modifier-plugin-api -> origin/dev/rfc-value-modifier-plugin-api
* [new branch] dev/standalone-home-logo-contents-component -> origin/dev/standalone-home-logo-contents-component
* [new branch] dev/stylesheet_importer_categories_with_background_images-modifier -> origin/dev/stylesheet_importer_categories_with_background_images-modifier
* [new branch] dev/third-party-breadcrumbs -> origin/dev/third-party-breadcrumbs
* [new branch] dev_add_query_param -> origin/dev_add_query_param
* [new branch] dev_lazy_load_categories_tests -> origin/dev_lazy_load_categories_tests
* [new branch] dev_update_category_position -> origin/dev_update_category_position
* [new branch] docs-publishing-mvp -> origin/docs-publishing-mvp
+ 4ee1d627c...a9d0e7069 ember-4 -> origin/ember-4 (forced update)
* [new branch] expand-allowed-custom-emoji-images-types -> origin/expand-allowed-custom-emoji-images-types
* [new branch] extra-js-revert -> origin/extra-js-revert
* [new branch] feature/disable-failing-auth-methods -> origin/feature/disable-failing-auth-methods
* [new branch] feature/paste-upload-on-first-upload-input-templates -> origin/feature/paste-upload-on-first-upload-input-templates
* [new branch] feature/requires-confirmation-site-settings -> origin/feature/requires-confirmation-site-settings
2b7b460d7..953282535 feature/shift-auto-upload-dropped-files-chat -> origin/feature/shift-auto-upload-dropped-files-chat
07d05ab18..506fa1c7c feature/show-status-on-mentions-when-user-havent-used-autocomplete -> origin/feature/show-status-on-mentions-when-user-havent-used-autocomplete
* [new branch] feature/user-fields-required-for-existing-users-2 -> origin/feature/user-fields-required-for-existing-users-2
* [new branch] feature_track_mentions -> origin/feature_track_mentions
* [new branch] fix-bbcode-parser -> origin/fix-bbcode-parser
* [new branch] fix-display-errors-for-history-modal-when-fetching-revisions -> origin/fix-display-errors-for-history-modal-when-fetching-revisions
* [new branch] fix-password-reset-security-key -> origin/fix-password-reset-security-key
* [new branch] fix_default_value_validation_fail -> origin/fix_default_value_validation_fail
* [new branch] fix_reviewable_translation -> origin/fix_reviewable_translation
* [new branch] formtoolkit -> origin/formtoolkit
* [new branch] full-page -> origin/full-page
* [new branch] generic-import-add-suspender -> origin/generic-import-add-suspender
* [new branch] generic-import-latest -> origin/generic-import-latest
* [new branch] glimmer-header-dnd-live -> origin/glimmer-header-dnd-live
* [new branch] grant-admin-fetch-user -> origin/grant-admin-fetch-user
* [new branch] hijacks -> origin/hijacks
* [new branch] html-table -> origin/html-table
* [new branch] i18n-helper-import -> origin/i18n-helper-import
* [new branch] image-assets -> origin/image-assets
* [new branch] implicit-injections-deprecations -> origin/implicit-injections-deprecations
* [new branch] improve-claimed-reviewables-transactions -> origin/improve-claimed-reviewables-transactions
* [new branch] independent-theme-compiler -> origin/independent-theme-compiler
* [new branch] input-text-field-component -> origin/input-text-field-component
* [new branch] issue/fixup-upload-ref-backfill-migration-dates -> origin/issue/fixup-upload-ref-backfill-migration-dates
* [new branch] jjaffeux-otp-validation -> origin/jjaffeux-otp-validation
* [new branch] lazy-fabricators -> origin/lazy-fabricators
* [new branch] list-wrapper -> origin/list-wrapper
* [new branch] live-cache -> origin/live-cache
* [new branch] loic-update-to-rails-7.1 -> origin/loic-update-to-rails-7.1
* [new branch] member-xp/mobile-modal -> origin/member-xp/mobile-modal
* [new branch] migrations-tooling/converter -> origin/migrations-tooling/converter
* [new branch] mock-chat-index-redesign -> origin/mock-chat-index-redesign
* [new branch] modify-class-native-syntax -> origin/modify-class-native-syntax
* [new branch] more-topics-active -> origin/more-topics-active
* [new branch] nested-job-example -> origin/nested-job-example
* [new branch] oklab -> origin/oklab
* [new branch] omniauth-2 -> origin/omniauth-2
* [new branch] optimize-chat-email-notification -> origin/optimize-chat-email-notification
* [new branch] plugin-outlet-no-subdir -> origin/plugin-outlet-no-subdir
* [new branch] post-widget-outlet -> origin/post-widget-outlet
* [new branch] powered-by-reactivity -> origin/powered-by-reactivity
* [new branch] pretty-text-please -> origin/pretty-text-please
* [new branch] promote-migration-tweak -> origin/promote-migration-tweak
* [new branch] relative-sourcemap -> origin/relative-sourcemap
* [new branch] release-31-README-updates -> origin/release-31-README-updates
* [new branch] remap-assume-yes-option -> origin/remap-assume-yes-option
* [new branch] remove-bootbox -> origin/remove-bootbox
* [new branch] remove-disable-sidebar -> origin/remove-disable-sidebar
* [new branch] remove-summarization -> origin/remove-summarization
* [new branch] remove-x-count -> origin/remove-x-count
* [new branch] revert-thread-title-experiment -> origin/revert-thread-title-experiment
* [new branch] see_if_yarn_cache_is_working -> origin/see_if_yarn_cache_is_working
* [new branch] shared-draft-category -> origin/shared-draft-category
* [new branch] skip-topic-bookmark-sync-user-destroy -> origin/skip-topic-bookmark-sync-user-destroy
cec7c05da..a721e8fa4 stable -> origin/stable
* [new branch] support-query-string -> origin/support-query-string
* [new branch] support_s3_inventory_bucket -> origin/support_s3_inventory_bucket
7de3cb9b0..c13f64d35 tests-passed -> origin/tests-passed
* [new branch] tippy-arrow-fix -> origin/tippy-arrow-fix
* [new branch] tobiaseigen-patch-2 -> origin/tobiaseigen-patch-2
* [new branch] topic-count-fix -> origin/topic-count-fix
* [new branch] tweak-feature-items -> origin/tweak-feature-items
* [new branch] update-gems-stable -> origin/update-gems-stable
* [new branch] update-official-plugin-list -> origin/update-official-plugin-list
* [new branch] user-menu-full-name -> origin/user-menu-full-name
* [new branch] with-ancestor-ids -> origin/with-ancestor-ids
t [tag update] beta -> beta
t [tag update] latest-release -> latest-release
* [new tag] v3.0.5 -> v3.0.5
* [new tag] v3.0.6 -> v3.0.6
* [new tag] v3.1.0 -> v3.1.0
* [new tag] v3.1.0.beta6 -> v3.1.0.beta6
* [new tag] v3.1.0.beta7 -> v3.1.0.beta7
* [new tag] v3.1.0.beta8 -> v3.1.0.beta8
* [new tag] v3.1.1 -> v3.1.1
* [new tag] v3.1.2 -> v3.1.2
* [new tag] v3.1.3 -> v3.1.3
* [new tag] v3.1.4 -> v3.1.4
* [new tag] v3.1.5 -> v3.1.5
* [new tag] v3.2.0 -> v3.2.0
* [new tag] v3.2.0.beta1 -> v3.2.0.beta1
* [new tag] v3.2.0.beta2 -> v3.2.0.beta2
* [new tag] v3.2.0.beta3 -> v3.2.0.beta3
* [new tag] v3.2.0.beta4 -> v3.2.0.beta4
* [new tag] v3.2.0.beta5 -> v3.2.0.beta5
* [new tag] v3.2.1 -> v3.2.1
* [new tag] v3.2.2 -> v3.2.2
* [new tag] v3.3.0.beta1 -> v3.3.0.beta1
* [new tag] v3.3.0.beta2 -> v3.3.0.beta2
I, [2024-06-07T19:55:08.023740 #1] INFO -- :
I, [2024-06-07T19:55:08.023862 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
set -o errexit
if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
git pull
else
git -c advice.detachedHead=false checkout tests-passed
fi
Switched to a new branch 'tests-passed'
I, [2024-06-07T19:55:15.557075 #1] INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2024-06-07T19:55:15.557210 #1] INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2024-06-07T19:55:15.566702 #1] INFO -- :
I, [2024-06-07T19:55:15.566784 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2024-06-07T19:55:15.569407 #1] INFO -- :
I, [2024-06-07T19:55:15.569480 #1] INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2024-06-07T19:55:15.571969 #1] INFO -- :
I, [2024-06-07T19:55:15.572055 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2024-06-07T19:55:15.574915 #1] INFO -- :
I, [2024-06-07T19:55:15.575018 #1] INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2024-06-07T19:55:15.577820 #1] INFO -- :
I, [2024-06-07T19:55:15.577893 #1] INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2024-06-07T19:55:15.580341 #1] INFO -- :
I, [2024-06-07T19:55:15.580421 #1] INFO -- : > cd /var/www/discourse && mkdir -p /shared/log/rails
I, [2024-06-07T19:55:15.583008 #1] INFO -- :
I, [2024-06-07T19:55:15.583085 #1] INFO -- : > cd /var/www/discourse && bash -c "touch -a /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2024-06-07T19:55:15.586746 #1] INFO -- :
I, [2024-06-07T19:55:15.586821 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2024-06-07T19:55:15.590473 #1] INFO -- :
I, [2024-06-07T19:55:15.590548 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/{uploads,backups}"
I, [2024-06-07T19:55:15.594389 #1] INFO -- :
I, [2024-06-07T19:55:15.594466 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/{uploads,backups} /var/www/discourse/public"
I, [2024-06-07T19:55:15.598299 #1] INFO -- :
I, [2024-06-07T19:55:15.598376 #1] INFO -- : > cd /var/www/discourse && bash -c "mkdir -p /shared/tmp/{backups,restores}"
I, [2024-06-07T19:55:15.602210 #1] INFO -- :
I, [2024-06-07T19:55:15.602286 #1] INFO -- : > cd /var/www/discourse && bash -c "ln -s /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2024-06-07T19:55:15.605813 #1] INFO -- :
I, [2024-06-07T19:55:15.605887 #1] INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2024-06-07T19:55:16.258613 #1] INFO -- :
I, [2024-06-07T19:55:16.258748 #1] INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2024-06-07T19:55:16.260917 #1] INFO -- :
I, [2024-06-07T19:55:16.261134 #1] INFO -- : Remplacement de # redis par sv start redis || exit 1 dans /etc/service/unicorn/run
I, [2024-06-07T19:55:16.261609 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2024-06-07T19:55:18.097044 #1] INFO -- :
I, [2024-06-07T19:55:18.097188 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-solved.git
Cloning into 'discourse-solved'...
I, [2024-06-07T19:55:19.120279 #1] INFO -- :
I, [2024-06-07T19:55:19.120403 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-user-notes.git
Cloning into 'discourse-user-notes'...
I, [2024-06-07T19:55:20.180140 #1] INFO -- :
I, [2024-06-07T19:55:20.180258 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-encrypt.git
Cloning into 'discourse-encrypt'...
I, [2024-06-07T19:55:21.528291 #1] INFO -- :
I, [2024-06-07T19:55:21.528408 #1] INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-oauth2-basic.git
Cloning into 'discourse-oauth2-basic'...
I, [2024-06-07T19:55:22.487293 #1] INFO -- :
I, [2024-06-07T19:55:22.487665 #1] INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2024-06-07T19:55:22.534624 #1] INFO -- :
I, [2024-06-07T19:55:22.534862 #1] INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2024-06-07T19:55:22.536778 #1] INFO -- :
I, [2024-06-07T19:55:22.536851 #1] INFO -- : > mkdir -p /var/nginx/cache
I, [2024-06-07T19:55:22.538899 #1] INFO -- :
I, [2024-06-07T19:55:22.545823 #1] INFO -- : Remplacement de pid /run/nginx.pid; par daemon off; dans /etc/nginx/nginx.conf
I, [2024-06-07T19:55:22.546136 #1] INFO -- : Remplacement de (?m-ix:upstream[^\}]+\}) par upstream discourse { server 127.0.0.1:3000; } dans /etc/nginx/conf.d/discourse.conf
I, [2024-06-07T19:55:22.546919 #1] INFO -- : Remplacement de (?-mix:server_name.+$) par server_name _ ; dans /etc/nginx/conf.d/discourse.conf
I, [2024-06-07T19:55:22.547486 #1] INFO -- : Remplacement de (?-mix:client_max_body_size.+$) par client_max_body_size $upload_size ; dans /etc/nginx/conf.d/discourse.conf
I, [2024-06-07T19:55:22.548073 #1] INFO -- : Remplacement de (?-mix:worker_connections.+$) par worker_connections $nginx_worker_connections ; dans /etc/nginx/nginx.conf
I, [2024-06-07T19:55:22.548725 #1] INFO -- : > echo "done configuring web"
I, [2024-06-07T19:55:22.550253 #1] INFO -- : done configuring web
I, [2024-06-07T19:55:22.550489 #1] INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2024-06-07T19:55:23.939905 #1] INFO -- : Successfully installed bundler-2.5.3
1 gem installed
I, [2024-06-07T19:55:23.940009 #1] INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2024-06-07T19:55:29.214835 #1] INFO -- :
I, [2024-06-07T19:55:29.215199 #1] INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
rm -rf app/assets/javascripts/node_modules
fi
I, [2024-06-07T19:55:29.217107 #1] INFO -- :
I, [2024-06-07T19:55:29.217217 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
error ember-template-lint@6.0.0: The engine "node" is incompatible with this module. Expected version "^18.18.0 || ^20.9.0 || >=21.1.0". Got "18.16.1"
error Found incompatible module.
I, [2024-06-07T19:56:15.076884 #1] INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
I, [2024-06-07T19:56:15.077290 #1] INFO -- : Terminating async processes
I, [2024-06-07T19:56:15.077329 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
I, [2024-06-07T19:56:15.077363 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 103
2024-06-07 19:56:15.077 UTC [42] LOG: received fast shutdown request
103:signal-handler (1717790175) Received SIGTERM scheduling shutdown...
2024-06-07 19:56:15.122 UTC [42] LOG: aborting any active transactions
2024-06-07 19:56:15.124 UTC [42] LOG: background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-06-07 19:56:15.124 UTC [46] LOG: shutting down
103:M 07 Jun 2024 19:56:15.139 # User requested shutdown...
103:M 07 Jun 2024 19:56:15.139 * Saving the final RDB snapshot before exiting.
103:M 07 Jun 2024 19:56:15.161 * DB saved on disk
103:M 07 Jun 2024 19:56:15.161 # Redis is now ready to exit, bye bye...
2024-06-07 19:56:15.186 UTC [42] LOG: database system is shut down
ÉCHEC
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' a échoué avec le code de retour #<Process::Status: pid 332 exit 1>
Lieu de l'échec : /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec a échoué avec les paramètres {"cd"=>"$home", "cmd"=>["if [ \"$version\" != \"tests-passed\" ]; then\n rm -rf app/assets/javascripts/node_modules\nfi", "su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
L'initialisation a échoué avec le code de sortie 1
** ÉCHEC DE L'INITIALISATION ** veuillez faire défiler vers le haut et rechercher les messages d'erreur précédents, il peut y en avoir plus d'un.
./discourse-doctor peut aider à diagnostiquer le problème.
51dd434472ada6eab91b042f3f842661db261c56cbed5f43a44645ab1b7450a6
