Do you believe this ? the rebuild succeeded and the website is back online just after removing google drive backup plugin
- git clone https://github.com/berlindiamonds/discourse-sync-to-googledrive.git
Thank you so much sir.
Please report that problem to their GitHub repository, so they can look into it. Also extract the full rebuild log from your previous attempts and attach it there.
i will, thanks a lot.
I was having the same exact issue! Thank you for posting about it, otherwise I may never figured it out! I uncommented the plugins as suggested.
Ya I saw that, problem is I’m at work and don’t have access to my logs at the moment so I’ll do it later when I can provide more information.
