Rebuild fails with "failed to load system roots and no roots provided"
While trying to update our discourse forum I bumped on this problem:
When running these command lines:
mlapeyre@poppy-project discourse]$ cd /var/discourse
[mlapeyre@poppy-project discourse]$ git pull
error: cannot open .git/FETCH_HEAD: Permission denied
[mlapeyre@poppy-project discourse]$ sudo git pull
Already up-to-date.
[mlapeyre@poppy-project discourse]$ sudo ./launcher rebuild app
which: no docker.io in (/usr/bin:/bin:/usr/sbin:/sbin)
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
Unable to find image 'discourse/discourse:1.0.15' locally
Pulling repository discourse/discourse
Get https://index.docker.io/v1/repositories/discourse/discourse/images: x509: failed to load system roots and no roots provided
Your Docker installation is not working correctly
See: https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=sam
Any idea what could solve the problem ?
What version of docker are you running? Can you try updating to 1.9?
That strongly suggests you don’t have any root CA certificates installed in the machine which you are running Docker on. Without those, HTTPS doesn’t work, because it doesn’t know if the certificates being presented by websites are legit.
Given your prompt style, I’m thinking you’re probably running a RHEL-alike distro, so the package you want to install is probably ca-certificates.
Indeed the problem was a missing file /etc/pki/tls/certs/ca-bundle.crt
