Rebuild failure: "extconf failed, exit code 1" -- due to old Docker?
I’ve got a rebuild that’s failing, I think due to this. It’s running Ubuntu 16.04 with Docker version 17.05.0-ce, build 89658be, which I know is suspect, but I wanted to give this person one more rebuild if at all possible.
I, [2023-12-06T16:10:12.656984 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4'
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
current directory:
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rbtrace-0.5.0/ext
/usr/local/bin/ruby extconf.rb
  -- tar zxvfo msgpack-1.1.0.tar.gz
  -- env CFLAGS=nil LDFLAGS=nil CC=nil
-- ./configure --disable-dependency-tracking --disable-shared --with-pic
--prefix=/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rbtrace-0.5.0/ext/dst/
--libdir=/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rbtrace-0.5.0/ext/dst/lib
*** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of necessary
libraries and/or headers.  Check the mkmf.log file for more details.  You may
need configuration options.
Provided configuration options:
        --with-opt-dir
        --without-opt-dir
        --with-opt-include
        --without-opt-include=${opt-dir}/include
        --with-opt-lib
        --without-opt-lib=${opt-dir}/lib
        --with-make-prog
        --without-make-prog
        --srcdir=.
        --curdir
        --ruby=/usr/local/bin/$(RUBY_BASE_NAME)
extconf.rb:6:in `sys': ./configure --disable-dependency-tracking
failed, please report to https://github.com/tmm1/rbtrace/issues (RuntimeError)
        from extconf.rb:42:in `block (2 levels) in <main>'
        from extconf.rb:34:in `chdir'
        from extconf.rb:34:in `block in <main>'
        from extconf.rb:30:in `chdir'
        from extconf.rb:30:in `<main>'
To see why this extension failed to compile, please check the mkmf.log which can
be found here:
/var/www/discourse/vendor/bundle/ruby/3.2.0/extensions/x86_64-linux/3.2.0/rbtrace-0.5.0/mkmf.log
root@www:/var/discourse# ./launcher rebuild app
WARNING: Docker version 17.05.0-ce deprecated, recommend upgrade to 17.06.2 or newer.
x86_64 arch detected.
WARNING: containers/app.yml file is world-readable. You can secure this file by running: chmod o-rwx containers/app.yml
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20231023-1945: Pulling from discourse/base
Digest: sha256:2b0eb484d20888cc2daadb690dcfa73522105650c1420212e99345a36a424d77
Status: Image is up to date for discourse/base:2.0.20231023-1945
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-12-06T16:07:07.394158 #1]  INFO -- : Reading from stdin
I, [2023-12-06T16:07:07.401986 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2023-12-06T16:07:07.472801 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-12-06T16:07:07.473766 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2023-12-06T16:07:07.483448 #1]  INFO -- :
I, [2023-12-06T16:07:07.485286 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-12-06T16:07:07.492124 #1]  INFO -- :
I, [2023-12-06T16:07:07.493335 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2023-12-06T16:07:07.499353 #1]  INFO -- :
I, [2023-12-06T16:07:07.500588 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2023-12-06T16:07:07.507193 #1]  INFO -- :
I, [2023-12-06T16:07:07.508374 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-12-06T16:07:07.514723 #1]  INFO -- :
I, [2023-12-06T16:07:07.516000 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/12/06 16:07:07 socat[17] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2023-12-06T16:07:07.543544 #1]  INFO -- :
I, [2023-12-06T16:07:07.544355 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-12-06T16:07:07.549264 #1]  INFO -- :
I, [2023-12-06T16:07:07.549978 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-12-06T16:07:07.554670 #1]  INFO -- :
I, [2023-12-06T16:07:07.555334 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-12-06T16:07:07.559798 #1]  INFO -- :
I, [2023-12-06T16:07:07.560895 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-12-06T16:07:07.565444 #1]  INFO -- :
I, [2023-12-06T16:07:07.575177 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2023-12-06T16:07:07.583472 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2023-12-06T16:07:07.593556 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2023-12-06T16:07:07.602131 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2023-12-06T16:07:07.603040 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-12-06T16:07:08.001408 #1]  INFO -- :
I, [2023-12-06T16:07:08.002703 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/
13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-12-06T16:07:08.006516 #1]  INFO -- :
I, [2023-12-06T16:07:08.007156 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-12-06T16:07:08.048363 #1]  INFO -- :
I, [2023-12-06T16:07:08.049524 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-12-06T16:07:08.055285 #1]  INFO -- :
I, [2023-12-06T16:07:08.056635 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-12-06T16:07:08.067823 #1]  INFO -- :
I, [2023-12-06T16:07:08.068692 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-12-06T16:07:08.074460 #1]  INFO -- :
I, [2023-12-06T16:07:08.077226 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.con
f
I, [2023-12-06T16:07:08.078863 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T16:07:08.080089 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T16:07:08.081228 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T16:07:08.082315 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T16:07:08.083334 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/mai
n/postgresql.conf
I, [2023-12-06T16:07:08.084197 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-12-06T16:07:08.093130 #1]  INFO -- :
I, [2023-12-06T16:07:08.094813 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T16:07:08.095967 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-12-06T16:07:08.097082 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/
postgresql.conf
I, [2023-12-06T16:07:08.098475 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-12-06T16:07:08.099453 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-12-06T16:07:08.100346 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-12-06T16:07:08.101225 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postm
aster -D /etc/postgresql/13/main
I, [2023-12-06T16:07:08.105497 #1]  INFO -- : > sleep 5
2023-12-06 16:07:08.222 UTC [40] LOG:  starting PostgreSQL 13.12 (Debian 13.12-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-12-06 16:07:08.223 UTC [40] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-12-06 16:07:08.224 UTC [40] LOG:  listening on IPv6 address "::", port 5432
2023-12-06 16:07:08.228 UTC [40] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-12-06 16:07:08.236 UTC [43] LOG:  database system was shut down at 2023-12-06 16:06:59 UTC
2023-12-06 16:07:08.249 UTC [40] LOG:  database system is ready to accept connections
I, [2023-12-06T16:07:13.114589 #1]  INFO -- :
I, [2023-12-06T16:07:13.114892 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2023-12-06 16:07:13.233 UTC [53] postgres@postgres ERROR:  database "discourse" already exists
2023-12-06 16:07:13.233 UTC [53] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2023-12-06T16:07:13.238163 #1]  INFO -- :
I, [2023-12-06T16:07:13.239077 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-12-06 16:07:13.337 UTC [57] postgres@discourse ERROR:  role "discourse" already exists
2023-12-06 16:07:13.337 UTC [57] postgres@discourse STATEMENT:  create user discourse;
I, [2023-12-06T16:07:13.341906 #1]  INFO -- :
I, [2023-12-06T16:07:13.342832 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-12-06T16:07:13.414866 #1]  INFO -- : GRANT
I, [2023-12-06T16:07:13.415706 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-12-06T16:07:13.488051 #1]  INFO -- : ALTER SCHEMA
I, [2023-12-06T16:07:13.488985 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2023-12-06T16:07:13.565797 #1]  INFO -- : CREATE EXTENSION
I, [2023-12-06T16:07:13.566695 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2023-12-06T16:07:13.631827 #1]  INFO -- : CREATE EXTENSION
I, [2023-12-06T16:07:13.632670 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists vector;"'
NOTICE:  extension "vector" already exists, skipping
I, [2023-12-06T16:07:13.699897 #1]  INFO -- : CREATE EXTENSION
I, [2023-12-06T16:07:13.700680 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-12-06T16:07:13.766672 #1]  INFO -- : CREATE EXTENSION
I, [2023-12-06T16:07:13.767617 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-12-06T16:07:13.836190 #1]  INFO -- : CREATE EXTENSION
I, [2023-12-06T16:07:13.837081 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists vector;"'
I, [2023-12-06T16:07:13.904254 #1]  INFO -- : CREATE EXTENSION
I, [2023-12-06T16:07:13.905131 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2023-12-06T16:07:13.911512 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-12-06T16:07:14.017559 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2023-12-06T16:07:14.025808 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2023-12-06T16:07:14.026677 #1]  INFO -- : > echo postgres installed!
I, [2023-12-06T16:07:14.031148 #1]  INFO -- : postgres installed!
I, [2023-12-06T16:07:14.039613 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2023-12-06T16:07:14.047348 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2023-12-06T16:07:14.054663 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2023-12-06T16:07:14.056288 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.058359 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.059363 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-12-06T16:07:14.063988 #1]  INFO -- :
I, [2023-12-06T16:07:14.065261 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.066441 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.068176 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.069623 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.072095 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-12-06T16:07:14.073689 #1]  INFO -- : > echo redis installed
I, [2023-12-06T16:07:14.079558 #1]  INFO -- : redis installed
I, [2023-12-06T16:07:14.080851 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-12-06T16:07:14.092037 #1]  INFO -- : logfile ""
I, [2023-12-06T16:07:14.092862 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-12-06T16:07:14.095644 #1]  INFO -- : > sleep 10
109:C 06 Dec 2023 16:07:14.118 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
109:C 06 Dec 2023 16:07:14.119 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=109, just started
109:C 06 Dec 2023 16:07:14.119 # Configuration loaded
109:M 06 Dec 2023 16:07:14.120 * monotonic clock: POSIX clock_gettime
109:M 06 Dec 2023 16:07:14.123 * Running mode=standalone, port=6379.
109:M 06 Dec 2023 16:07:14.123 # WARNING: The TCP backlog setting of 511 cannot be enforced because /proc/sys/net/core/somaxconn is set to the lower value of 128.
109:M 06 Dec 2023 16:07:14.123 # Server initialized
109:M 06 Dec 2023 16:07:14.124 * Loading RDB produced by version 7.0.7
109:M 06 Dec 2023 16:07:14.125 * RDB age 17 seconds
109:M 06 Dec 2023 16:07:14.125 * RDB memory usage when created 16.66 Mb
109:M 06 Dec 2023 16:07:14.212 * Done loading RDB, keys loaded: 24735, keys expired: 2.
109:M 06 Dec 2023 16:07:14.212 * DB loaded from disk: 0.088 seconds
109:M 06 Dec 2023 16:07:14.212 * Ready to accept connections
I, [2023-12-06T16:07:24.102624 #1]  INFO -- :
I, [2023-12-06T16:07:24.103423 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-12-06T16:07:24.111028 #1]  INFO -- : thpoff is installed!
I, [2023-12-06T16:07:24.111792 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-12-06T16:07:24.220317 #1]  INFO -- :
I, [2023-12-06T16:07:24.221265 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-12-06T16:07:24.335260 #1]  INFO -- :
I, [2023-12-06T16:07:24.336566 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you
should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-12-06T16:07:24.447936 #1]  INFO -- :
I, [2023-12-06T16:07:24.448990 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-12-06T16:07:24.456613 #1]  INFO -- :
I, [2023-12-06T16:07:24.462541 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2023-12-06T16:07:24.472173 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2023-12-06T16:07:24.483793 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2023-12-06T16:07:24.493548 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2023-12-06T16:07:24.503794 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2023-12-06T16:07:24.511755 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2023-12-06T16:07:24.512437 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-12-06T16:07:24.513223 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf
I, [2023-12-06T16:07:24.517456 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git reset --hard
137:C 06 Dec 2023 16:07:24.534 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
137:C 06 Dec 2023 16:07:24.534 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=137, just started
137:C 06 Dec 2023 16:07:24.534 # Configuration loaded
137:M 06 Dec 2023 16:07:24.535 * monotonic clock: POSIX clock_gettime
137:M 06 Dec 2023 16:07:24.536 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
137:M 06 Dec 2023 16:07:24.536 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (33858/33858), done.
I, [2023-12-06T16:07:29.876110 #1]  INFO -- : HEAD is now at 043b4a418 FIX: replaces data-tooltip usage by <DTooltip /> (#24062)
I, [2023-12-06T16:07:29.876964 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git clean -f
I, [2023-12-06T16:07:30.100602 #1]  INFO -- :
I, [2023-12-06T16:07:30.101495 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
From https://github.com/discourse/discourse
 - [deleted]             (none)     -> origin/0-flake-key
 - [deleted]             (none)     -> origin/0-obscuring
 - [deleted]             (none)     -> origin/0-router-lint
 - [deleted]             (none)     -> origin/0-router-service
 - [deleted]             (none)     -> origin/autoimport-cleanup
 - [deleted]             (none)     -> origin/category-bullet-only
 - [deleted]             (none)     -> origin/dependabot/bundler/syntax_tree-6.2.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.4.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.8.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.6.0
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.5.2
 - [deleted]             (none)     -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.4.2
 - [deleted]             (none)     -> origin/dev-upgrade-reject-reason-reviewable-modal
 - [deleted]             (none)     -> origin/dev/ability-to-collect-stats-without-public-exposing
 - [deleted]             (none)     -> origin/dev/minio-s3-system-specs
 - [deleted]             (none)     -> origin/dev/re-enable-minio-specs
 - [deleted]             (none)     -> origin/dev/switch-over-category-settings
 - [deleted]             (none)     -> origin/dev/switch-over-more-category-settings
 - [deleted]             (none)     -> origin/discovery-named-outlets
 - [deleted]             (none)     -> origin/feature/theme-settings-migration
 - [deleted]             (none)     -> origin/fix/account-for-empty-string-site-settings
 - [deleted]             (none)     -> origin/footnote-plugin
 - [deleted]             (none)     -> origin/metadata-update
 - [deleted]             (none)     -> origin/modal-ux
 - [deleted]             (none)     -> origin/neil-2
 - [deleted]             (none)     -> origin/perf_cache_async_search
 - [deleted]             (none)     -> origin/spoiler-plugin
 - [deleted]             (none)     -> origin/support-search-customizationz
   043b4a418..22bb1c895  main                   -> origin/main
 * [new branch]          0-lint-suffix          -> origin/0-lint-suffix
 * [new branch]          0-rubocop              -> origin/0-rubocop
 * [new branch]          add-custom-emoji-sanitization-clean -> origin/add-custom-emoji-sanitization-clean
 * [new branch]          add-ds-store-to-gitignore -> origin/add-ds-store-to-gitignore
 + 64520a075...ff17131c9 add-new-chat-indicator-preference-only-mentions -> origin/add-new-chat-indicator-preference-only-mentions  (forced update)
 * [new branch]          api-topic-title-decorator -> origin/api-topic-title-decorator
 * [new branch]          array-custom-field-fix -> origin/array-custom-field-fix
 * [new branch]          array-custom-field-order -> origin/array-custom-field-order
 * [new branch]          avatar-notifications   -> origin/avatar-notifications
 * [new branch]          boosted-searches       -> origin/boosted-searches
 * [new branch]          category_definition    -> origin/category_definition
 * [new branch]          chat-github-onebox     -> origin/chat-github-onebox
 * [new branch]          chat-reaction-emoji-alignment -> origin/chat-reaction-emoji-alignment
 * [new branch]          chat/direct-messages   -> origin/chat/direct-messages
 * [new branch]          custom-field-store-cleanup -> origin/custom-field-store-cleanup
 * [new branch]          delete-backups-based-on-time-window -> origin/delete-backups-based-on-time-window
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.5.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-3.5.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.9.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/aws-s3-multipart-3.9.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.7.1 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/core-3.7.1
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.6.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/utils-5.6.0
 * [new branch]          dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.5.0 -> origin/dependabot/npm_and_yarn/app/assets/javascripts/uppy/xhr-upload-3.5.0
 * [new branch]          desktop-notification-handlers -> origin/desktop-notification-handlers
 * [new branch]          dev/add-a-reference-column-to-notifications -> origin/dev/add-a-reference-column-to-notifications
 + ee95e6359...346f9d1cd dev/add-new-chat-metrics -> origin/dev/add-new-chat-metrics  (forced update)
 * [new branch]          dev/dry-up-user-status-serializers -> origin/dev/dry-up-user-status-serializers
 * [new branch]          dev/flaky-chat-details-collapser-spec -> origin/dev/flaky-chat-details-collapser-spec
 * [new branch]          dev/no-need-to-include-user-status-twice -> origin/dev/no-need-to-include-user-status-twice
 * [new branch]          dev/rethink-mass-mentions -> origin/dev/rethink-mass-mentions
 * [new branch]          dev/rethink-mass-mentions-polymorphic -> origin/dev/rethink-mass-mentions-polymorphic
 * [new branch]          dev/revert-guardian-devex -> origin/dev/revert-guardian-devex
 * [new branch]          dev/use-system-user-id-const -> origin/dev/use-system-user-id-const
 + 54940ca5c...1f44361c2 dev_paginate_categories_json -> origin/dev_paginate_categories_json  (forced update)
 * [new branch]          dev_watched_words      -> origin/dev_watched_words
 + 46fe4511f...a9d0e7069 ember-4                -> origin/ember-4  (forced update)
 * [new branch]          ember-5-plugins        -> origin/ember-5-plugins
 * [new branch]          extract_stripper       -> origin/extract_stripper
 * [new branch]          feature/add-copy-share-link-post-functionality -> origin/feature/add-copy-share-link-post-functionality
   9a6c6fd5b..8780daeee  feature/bookmark-menu-and-modal-redesign -> origin/feature/bookmark-menu-and-modal-redesign
 * [new branch]          feature/migrations-schema-generator -> origin/feature/migrations-schema-generator
 * [new branch]          feature_watched_words_validation -> origin/feature_watched_words_validation
 * [new branch]          file-size-restriction  -> origin/file-size-restriction
   43df37774..4393dd37e  filtered-events        -> origin/filtered-events
 * [new branch]          fix-keyboard-shortcuts-modal-double-scrollbar -> origin/fix-keyboard-shortcuts-modal-double-scrollbar
 * [new branch]          fix/count-mass-mentions-correctly -> origin/fix/count-mass-mentions-correctly
 * [new branch]          fix_category_select_kits -> origin/fix_category_select_kits
 * [new branch]          full-page              -> origin/full-page
   ce7fb6906..a6227532d  generic-import-latest  -> origin/generic-import-latest
 * [new branch]          generic-import-latest-snowflake -> origin/generic-import-latest-snowflake
 * [new branch]          generic-import-update  -> origin/generic-import-update
 * [new branch]          image-assets           -> origin/image-assets
 * [new branch]          independent-theme-compiler -> origin/independent-theme-compiler
 * [new branch]          input-text-field-component -> origin/input-text-field-component
 * [new branch]          issue/fix-guardian-init-basic-user -> origin/issue/fix-guardian-init-basic-user
 * [new branch]          keyword-site-setting   -> origin/keyword-site-setting
 + bdcc24f96...92e545292 list-wrapper           -> origin/list-wrapper  (forced update)
   e3636078c..5def32699  mock-chat-index-redesign -> origin/mock-chat-index-redesign
 * [new branch]          move_inflector         -> origin/move_inflector
 * [new branch]          oklab                  -> origin/oklab
 * [new branch]          poc/auto-after-before-plugin-outlets -> origin/poc/auto-after-before-plugin-outlets
 * [new branch]          poc/insert-before-after-wrapping-outlet -> origin/poc/insert-before-after-wrapping-outlet
 * [new branch]          pretty-text-please     -> origin/pretty-text-please
 * [new branch]          revert-maxmind         -> origin/revert-maxmind
   ef3f41543..223626d7a  stable                 -> origin/stable
 * [new branch]          support-load-more-btn  -> origin/support-load-more-btn
 * [new branch]          test-issue-temporary   -> origin/test-issue-temporary
   043b4a418..efcb5bb3d  tests-passed           -> origin/tests-passed
 * [new branch]          transform-hooks        -> origin/transform-hooks
 * [new branch]          transform-post-fn-api  -> origin/transform-post-fn-api
 * [new branch]          tweaks-2-fr            -> origin/tweaks-2-fr
 * [new branch]          use-sassc-embedded     -> origin/use-sassc-embedded
 * [new branch]          username_cache         -> origin/username_cache
 * [new branch]          ux-add-sorting-params-to-outlet -> origin/ux-add-sorting-params-to-outlet
 t [tag update]          beta                   -> beta
 t [tag update]          latest-release         -> latest-release
 * [new tag]             v3.1.3                 -> v3.1.3
 * [new tag]             v3.2.0.beta3           -> v3.2.0.beta3
I, [2023-12-06T16:07:31.685641 #1]  INFO -- :
I, [2023-12-06T16:07:31.686339 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [[ $(git symbolic-ref --short HEAD) == tests-passed ]] ; then
      git pull
  else
      git -c advice.detachedHead=false checkout tests-passed
  fi
Switched to a new branch 'tests-passed'
I, [2023-12-06T16:07:35.620323 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2023-12-06T16:07:35.620991 #1]  INFO -- : > cd /var/www/discourse && sudo -H -E -u discourse git config user.discourse-version tests-passed
I, [2023-12-06T16:07:35.636731 #1]  INFO -- :
I, [2023-12-06T16:07:35.637527 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-12-06T16:07:35.643552 #1]  INFO -- :
I, [2023-12-06T16:07:35.644234 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-12-06T16:07:35.650138 #1]  INFO -- :
I, [2023-12-06T16:07:35.650972 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-12-06T16:07:35.656320 #1]  INFO -- :
I, [2023-12-06T16:07:35.657036 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-12-06T16:07:35.662104 #1]  INFO -- :
I, [2023-12-06T16:07:35.662758 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-12-06T16:07:35.669054 #1]  INFO -- :
I, [2023-12-06T16:07:35.669975 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2023-12-06T16:07:35.676933 #1]  INFO -- :
I, [2023-12-06T16:07:35.677771 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.lo
g"
I, [2023-12-06T16:07:35.687445 #1]  INFO -- :
I, [2023-12-06T16:07:35.688203 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.lo
g /var/www/discourse/log"
I, [2023-12-06T16:07:35.697439 #1]  INFO -- :
I, [2023-12-06T16:07:35.698219 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2023-12-06T16:07:35.705472 #1]  INFO -- :
I, [2023-12-06T16:07:35.706224 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-12-06T16:07:35.714941 #1]  INFO -- :
I, [2023-12-06T16:07:35.715579 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2023-12-06T16:07:35.722744 #1]  INFO -- :
I, [2023-12-06T16:07:35.723466 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-12-06T16:07:35.730272 #1]  INFO -- :
I, [2023-12-06T16:07:35.730904 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-12-06T16:07:36.244295 #1]  INFO -- :
I, [2023-12-06T16:07:36.245006 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-12-06T16:07:36.248521 #1]  INFO -- :
I, [2023-12-06T16:07:36.249238 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-12-06T16:07:36.249835 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2023-12-06T16:07:37.086735 #1]  INFO -- :
I, [2023-12-06T16:07:37.087632 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T16:07:37.095997 #1]  INFO -- :
I, [2023-12-06T16:07:37.097169 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-12-06T16:07:37.102877 #1]  INFO -- :
I, [2023-12-06T16:07:37.103777 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2023-12-06T16:07:37.109509 #1]  INFO -- :
I, [2023-12-06T16:07:37.110962 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-12-06T16:07:37.111761 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T16:07:37.112365 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T16:07:37.112934 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-12-06T16:07:37.113518 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-12-06T16:07:37.113925 #1]  INFO -- : > echo "done configuring web"
I, [2023-12-06T16:07:37.116639 #1]  INFO -- : done configuring web
I, [2023-12-06T16:07:37.117373 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2023-12-06T16:07:37.381140 #1]  INFO -- :
I, [2023-12-06T16:07:37.381751 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2023-12-06T16:07:42.260626 #1]  INFO -- :
I, [2023-12-06T16:07:42.266374 #1]  INFO -- : > cd /var/www/discourse && if [ "tests-passed" != "tests-passed" ]; then
  rm -rf app/assets/javascripts/node_modules
fi
I, [2023-12-06T16:07:42.275364 #1]  INFO -- :
I, [2023-12-06T16:07:42.276177 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'
warning " > @glint/environment-ember-loose@1.1.0" has unmet peer dependency "@glimmer/component@^1.1.2".
warning " > @glint/environment-ember-template-imports@1.1.0" has unmet peer dependency "ember-template-imports@^3.0.0".
warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
warning Pattern ["wrap-ansi@^7.0.0"] is trying to unpack in the same destination "/home/discourse/.cache/yarn/v6/npm-wrap-ansi-cjs-7.0.0-67e145cff510a6a6984bdf1152911d69d2eb9e43-integrity/no
de_modules/wrap-ansi-cjs" as pattern ["wrap-ansi-cjs@npm:wrap-ansi@^7.0.0"]. This could result in non-deterministic behavior, skipping.
warning " > discourse-markdown-it@1.0.0" has unmet peer dependency "xss@*".
warning "workspace-aggregator-91e584d3-820f-4c50-a600-62c805fec825 > discourse > @ember/legacy-built-in-components@0.5.0" has incorrect peer dependency "ember-source@>= 4.8".
warning "workspace-aggregator-91e584d3-820f-4c50-a600-62c805fec825 > discourse > @uppy/aws-s3@3.0.6" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-91e584d3-820f-4c50-a600-62c805fec825 > discourse > @uppy/aws-s3-multipart@3.1.3" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-91e584d3-820f-4c50-a600-62c805fec825 > discourse > @uppy/xhr-upload@3.1.1" has incorrect peer dependency "@uppy/core@^3.1.2".
warning "workspace-aggregator-91e584d3-820f-4c50-a600-62c805fec825 > discourse-plugins > ember-this-fallback@0.4.0" has unmet peer dependency "ember-source@^3.28.11 || ^4.0.0".
warning "workspace-aggregator-91e584d3-820f-4c50-a600-62c805fec825 > discourse > @uppy/aws-s3 > @uppy/xhr-upload@3.3.0" has incorrect peer dependency "@uppy/core@^3.2.1".
I, [2023-12-06T16:10:11.898082 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts $(node -e 'const argv = JSON.parse(process.env.npm_config_argv).original; const passthrough = [`--frozen-lockfile`, `-s`].filter(arg => argv.includes(arg)
); console.log(passthrough.join(` `));')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
$ ./run-patch-package
patch-package 8.0.0
Applying patches...
babel-plugin-debug-macros@0.3.4 ✔
content-tag@1.1.2 ✔
ember-cli@5.0.0 ✔
ember-this-fallback@0.4.0 (1 deprecation-name) ✔
ember-this-fallback@0.4.0 (2 themes) ✔
virtual-dom@2.1.1 ✔
Done in 72.34s.
Done in 135.83s.
yarn cache v1.22.19
success Cleared cache.
Done in 13.11s.
I, [2023-12-06T16:10:11.904393 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local deployment true'
I, [2023-12-06T16:10:12.394395 #1]  INFO -- :
I, [2023-12-06T16:10:12.395124 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle config --local without "development test"'
I, [2023-12-06T16:10:12.656177 #1]  INFO -- : You are replacing the current local value of without, which is currently "test:development"
current directory:
        --with-opt-dir
        --without-opt-dir
        --with-opt-include
        --with-opt-lib
        --with-make-prog
        --without-make-prog
        --srcdir=.
        --curdir
be found here:
Gem files will remain installed in
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rbtrace-0.5.0 for inspection.
Results logged to
/var/www/discourse/vendor/bundle/ruby/3.2.0/extensions/x86_64-linux/3.2.0/rbtrace-0.5.0/gem_make.out
  /usr/local/lib/ruby/site_ruby/3.2.0/rubygems/ext/builder.rb:120:in `run'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/ext/ext_conf_builder.rb:28:in
`build'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/ext/builder.rb:188:in
`build_extension'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/ext/builder.rb:222:in `block in
build_extensions'
  /usr/local/lib/ruby/site_ruby/3.2.0/rubygems/ext/builder.rb:219:in `each'
`build_extensions'
/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/installer.rb:844:in
`build_extensions'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/rubygems_gem_installer.rb:72:in
`build_extensions'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/rubygems_gem_installer.rb:28:in
`install'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/source/rubygems.rb:198:in
`install'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/installer/gem_installer.rb:54:in
`install'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/installer/gem_installer.rb:16:in
`install_from_spec'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/installer/parallel_installer.rb:156:in
`do_install'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/installer/parallel_installer.rb:147:in
`block in worker_pool'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/worker.rb:62:in
`apply_func'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/worker.rb:57:in
`block in process_queue'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/worker.rb:54:in
`loop'
`process_queue'
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.4.13/lib/bundler/worker.rb:90:in
`block (2 levels) in create_threads'
An error occurred while installing rbtrace (0.5.0), and Bundler cannot continue.
In Gemfile:
  rbtrace
I, [2023-12-06T16:10:45.706190 #1]  INFO -- : Fetching gem metadata from https://rubygems.org/.........
Fetching rake 13.1.0
Installing rake 13.1.0
Using concurrent-ruby 1.2.2
Fetching racc 1.7.3
Using builder 3.2.4
Using minitest 5.20.0
Using erubi 1.12.0
Using mini_mime 1.1.5
Fetching date 3.3.4
Using crass 1.0.6
Using rack 2.2.8
Fetching public_suffix 5.0.4
Fetching timeout 0.4.1
Installing timeout 0.4.1
Installing date 3.3.4 with native extensions
Installing racc 1.7.3 with native extensions
Installing public_suffix 5.0.4
Fetching aws-eventstream 1.3.0
Using aws-partitions 1.583.0
Using jmespath 1.6.2
Fetching base64 0.2.0
Installing aws-eventstream 1.3.0
Using msgpack 1.7.2
Using bundler 2.4.13
Installing base64 0.2.0
Using byebug 11.1.3
Using cbor 0.5.9.6
Fetching cgi 0.4.1
Using chunky_png 1.4.0
Using coderay 1.1.3
Using colored2 4.0.0
Using connection_pool 2.4.1
Using openssl 3.2.0
Using cppjieba_rb 0.4.2
Fetching google-protobuf 3.25.1 (x86_64-linux)
Installing cgi 0.4.1 with native extensions
Installing google-protobuf 3.25.1 (x86_64-linux)
Using diffy 3.4.2
Using digest 3.1.1
Using discourse-fonts 0.0.9
Using email_reply_trimmer 0.1.13
Fetching excon 0.105.0
Installing excon 0.105.0
Using execjs 2.9.1
Using exifr 1.4.0
Using faraday-net_http 3.0.2
Using ruby2_keywords 0.0.5
Using fast_blank 1.0.1
Using fast_xs 0.8.0
Using fastimage 2.2.7
Using ffi 1.16.3
Using fspath 3.1.2
Using gc_tracer 1.5.1
Using guess_html_encoding 0.0.11
Using hana 1.3.7
Using hashie 5.0.0
Using highline 2.1.0
Using htmlentities 4.3.4
Using http_accept_language 2.1.1
Using image_size 3.3.0
Using in_threads 1.6.0
Using progress 3.6.0
Fetching json 2.7.1
Installing json 2.7.1 with native extensions
Fetching regexp_parser 2.8.3
Installing regexp_parser 2.8.3
Fetching unf_ext 0.0.9.1
Installing unf_ext 0.0.9.1 with native extensions
Using jwt 2.7.1
Using kgio 2.11.4
Using libv8-node 18.16.0.0 (x86_64-linux)
Using method_source 1.0.0
Using thor 1.3.0
Using zeitwerk 2.6.12
Using logstash-event 1.2.02
Fetching logster 2.13.1
Installing logster 2.13.1
Using lru_redux 1.1.0
Using lz4-ruby 0.3.3
Using maxminddb 0.1.22
Using memory_profiler 1.0.1
Using redis 4.8.1
Using mini_sql 1.5.0
Using multi_json 1.15.0
Using multi_xml 0.6.0
Using mustache 1.1.1
Fetching uri 0.13.0
Installing uri 0.13.0
Fetching nio4r 2.7.0
Installing nio4r 2.7.0 with native extensions
Using version_gem 1.1.3
Using oj 3.16.1
Using optimist 3.1.0
Using pg 1.5.4
Using raindrops 0.20.1
Using rchardet 1.8.0
Using rexml 3.2.6
Using rinku 2.0.6
Using rotp 6.3.0
Using rqrcode_core 1.2.0
Using rubyzip 2.3.2
Using sshkey 3.0.0
Using stackprof 0.2.25
Using i18n 1.14.1
Using tzinfo 2.0.6
Using rack-test 2.1.0
Using request_store 1.5.1
Using message_bus 4.3.8
Using rack-mini-profiler 3.1.1
Using rack-protection 3.1.0
Using sprockets 3.7.2 from https://github.com/rails/sprockets (at 3.x@f4d3dae)
Fetching net-protocol 0.2.2
Installing net-protocol 0.2.2
Using addressable 2.8.5
Using aws-sigv4 1.5.0
Fetching bootsnap 1.17.0
Installing bootsnap 1.17.0 with native extensions
Using openssl-signature_algorithm 1.3.0
Fetching sass-embedded 1.66.1 (x86_64-linux-gnu)
Installing sass-embedded 1.66.1 (x86_64-linux-gnu)
Using uglifier 4.2.0
Fetching faraday 2.7.12
Installing faraday 2.7.12
Using mini_suffix 0.3.3
Using omniauth 1.9.2
Using image_optim 0.31.3
Fetching nokogiri 1.15.5 (x86_64-linux)
Installing nokogiri 1.15.5 (x86_64-linux)
Fetching web-push 3.0.1
Installing web-push 3.0.1
Using mini_racer 0.8.0
Using pry 0.14.2
Using logstash-logger 0.26.1
Using sidekiq 6.5.12
Using redis-namespace 1.11.0
Fetching net-http 0.4.0
Using unf 0.1.4
Using oauth-tty 1.0.5
Using snaky_hash 2.0.1
Fetching rbtrace 0.5.0
Installing rbtrace 0.5.0 with native extensions
Installing net-http 0.4.0
Using unicorn 6.1.0
Using rss 0.3.0
Using rqrcode 2.2.0
Using activesupport 7.0.7
Using tzinfo-data 1.2023.3
Using net-pop 0.1.2
Using net-smtp 0.4.0
Using css_parser 1.16.0
Using aws-sdk-core 3.130.2
Using cose 1.3.0
Fetching dartsass-ruby 3.0.2
Installing dartsass-ruby 3.0.2
Using faraday-retry 2.2.0
Using oauth2 1.4.11
Using rtlcss 0.2.1
Using pry-byebug 3.10.1
Using pry-rails 0.3.9
Fetching loofah 2.22.0
Installing loofah 2.22.0
Using ruby-readability 0.7.0
Using sanitize 6.1.0
Using simpleidn 0.2.1
Using mini_scheduler 0.16.0
Using oauth 1.1.0
Using rails-dom-testing 2.2.0
Using globalid 1.2.1
Using activemodel 7.0.7
Using aws-sdk-kms 1.56.0
Using aws-sdk-sns 1.53.0
Using omniauth-oauth2 1.7.3
Using rails-html-sanitizer 1.6.0
Fetching json_schemer 2.1.1
Installing json_schemer 2.1.1
Using omniauth-oauth 1.2.0
Using activejob 7.0.7
Using active_model_serializers 0.8.4
Using activerecord 7.0.7
Using actionview 7.0.7
Using aws-sdk-s3 1.114.0
Using omniauth-facebook 9.0.0
Using omniauth-github 1.4.0
Using omniauth-google-oauth2 0.8.2
Using omniauth-twitter 1.4.0
Using discourse-seed-fu 2.3.12
Using actionpack 7.0.7
Using actionview_precompiler 0.3.0
Using railties 7.0.7
Using sprockets-rails 3.4.2
Using lograge 0.14.0
Using rails_failover 2.0.1
Using rails_multisite 5.0.0
Using puma 6.4.0
Fetching net-imap 0.4.7
Installing net-imap 0.4.7
Using mail 2.8.1
Using actionmailer 7.0.7
I, [2023-12-06T16:10:45.708604 #1]  INFO -- : Terminating async processes
I, [2023-12-06T16:10:45.708734 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql
/13/bin/postmaster -D /etc/postgresql/13/main pid: 40
I, [2023-12-06T16:10:45.709069 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 109
2023-12-06 16:10:45.709 UTC [40] LOG:  received fast shutdown request
109:signal-handler (1701879045) Received SIGTERM scheduling shutdown...
2023-12-06 16:10:45.713 UTC [40] LOG:  aborting any active transactions
2023-12-06 16:10:45.721 UTC [40] LOG:  background worker "logical replication launcher" (PID 49) exited with exit code 1
2023-12-06 16:10:45.722 UTC [44] LOG:  shutting down
2023-12-06 16:10:45.746 UTC [40] LOG:  database system is shut down
109:M 06 Dec 2023 16:10:45.749 # User requested shutdown...
109:M 06 Dec 2023 16:10:45.750 * Saving the final RDB snapshot before exiting.
109:M 06 Dec 2023 16:10:45.855 * DB saved on disk
109:M 06 Dec 2023 16:10:45.856 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle install --retry 3 --jobs 4' failed with return #<Process::Status: pid 507 exit 5>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle config --local deployment true'", "su discourse -c 'bundle config --local without \"develo
pment test\"'", "su discourse -c 'bundle install --retry 3 --jobs 4'"]}
bootstrap failed with exit code 5
a3071aa235f86264227596c04c18b830cff475e4fa809d5a88ead626ab2cdf28
Could you post that log file?
I think that file is inside the container that’s failing to build, so it’ll be a bit hard to catch, I think. I think I saw someone else with a similar error that went away when they upgraded Docker (they were on a later OS), so I’m going to just think that’s what the problem is.
Thanks
Possibly. But on my system there’s a selection of such - might be worth a look, in case they are not just fossils.
ls -ltr /var/lib/docker/overlay2/*/*/var/www/discourse/vendor/bundle/ruby/3.2.0/extensions/x86_64-linux/3.2.0/rbtrace*/mkmf.log
Well. I’ll be.
Look!
root@www:~# find /var/lib/docker -name mkmf.log|grep rbtrac|xargs ls -tl
-rw-r--r-- 1 1000 1000 35035 Oct 23 19:45 /var/lib/docker/aufs/diff/53a65982150d745a518e8e8b3d1c4e5e21df4aeaf387d952d9018f688e676391/var/www/discourse/vendor/bundle/ruby/3.2.0/extensions/x86_64-linux/3.2.0/rbtrace-0.4.14/mkmf.log
-rw-r--r-- 1 1000 1000 35329 Apr  9  2023 /var/lib/docker/aufs/diff/f324a4557c610412bd944c93adb2b1cb93a3e368bbd10b4f3a7b0160d320be6c/var/www/discourse/vendor/bundle/ruby/3.2.0/extensions/x86_64-linux/3.2.0/rbtrace-0.4.14/mkmf.log
-rw-r--r-- 1 1000 1000 35329 Apr  9  2023 /var/lib/docker/aufs/mnt/de948aa2097c3527c79c437dbfae65d2c71bdde2843896306868d409ae4b0937/var/www/discourse/vendor/bundle/ruby/3.2.0/extensions/x86_64-linux/3.2.0/rbtrace-0.4.14/mkmf.log
-rw-r--r-- 1 1000 1000 35147 Dec 21  2022 /var/lib/docker/aufs/diff/484330416e5a8c7cda4005d144c20205d5410d62dd23a599b4e9b2d408510c13/var/www/discourse/vendor/bundle/ruby/3.1.0/extensions/x86_64-linux/3.1.0/rbtrace-0.4.14/mkmf.log
Looks like something like this is to blame:
have_func: checking for rb_gc_add_event_hook() in ruby.h,node.h... -------------------- no
LD_LIBRARY_PATH=.:/usr/local/lib "gcc -o conftest -I/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rbtrace-0.4.14/ext/dst/include -I/usr/local/include/ruby-3.2.0/x86_64-linux -I/usr/local/include/ruby-3.2.0/ruby/backward -I/usr/local/include/ruby-3.2.0 -I.    -O3 -fno-fast-math -ggdb3 -Wall -Wextra -Wdeprecated-declarations -Wdiv-by-zero -Wduplicated-cond -Wimplicit-function-declaration -Wimplicit-int -Wmisleading-indentation -Wpointer-arith -Wwrite-strings -Wold-style-definition -Wimplicit-fallthrough=0 -Wmissing-noreturn -Wno-cast-function-type -Wno-constant-logical-operand -Wno-long-long -Wno-missing-field-initializers -Wno-overlength-strings -Wno-packed-bitfield-compat -Wno-parentheses-equality -Wno-self-assign -Wno-tautological-compare -Wno-unused-parameter -Wno-unused-value -Wsuggest-attribute=format -Wsuggest-attribute=noreturn -Wunused-variable -Wundef  -fPIC conftest.c  -L. -L/usr/local/lib -Wl,-rpath,/usr/local/lib -L. -fstack-protector-strong -rdynamic -Wl,-export-dynamic -Wl,--no-as-needed    -lmsgpackc_ext  -Wl,-rpath,/usr/local/lib -L/usr/local/lib -lruby -lmsgpackc_ext  -lm -lpthread  -lc"
conftest.c:4:10: fatal error: node.h: No such file or directory
and also
conftest.c: In function ‘t’:
conftest.c:16:57: error: ‘rb_postponed_job_register_one’ undeclared (first use in this function)
   16 | int t(void) { void ((*volatile p)()); p = (void ((*)()))rb_postponed_job_register_one; return !p; }
Doesn’t make sense that this could be due to an old docker. But I’m still afraid to break this site without cause.
here is a link that expires in 12 hours.
Hmm might be a red herring, as I see the same fails and yet apparently nothing is broken in my case. Maybe these logs are some kind of fossil in the image?
Could be. Anyway, no one else has this problem, so I think I’m not going to worry about it and just tell this person that if they want to upgrade discourse they’ll have to update the vm and OS.
Thanks for your help
I just tried a rebuild on a standard docker installation (with Docker from Debian Bullseye, docker.io apt package) and it succeeded, so this at least establishes that self hosted installations are not broken, that is, that launcher rebuild is not reproducibly resulting in failed installations due to an rbtrace dependency problem.
I doubt Docker version is a factor here; rbtrace fails to build inside the container, and that is likely a result of missing or outdated dependencies also inside the container.
Is there any chance your clone of discourse_docker failed to git pull before starting the rebuild, and is thus on an old commit? Can’t hurt to manually git pull and ensure it’s on the latest commit of the main branch.
That’s a possibility. Recent launcher does a git pull (and it’s been a long time that it started doing to git pull). Maybe I’ll give it one more try.
It’s definitely an edge case of some sort.
This may help someone as it worked for us without upgrading the Ubuntu 16.
  1. Run sudo apt update && sudo apt upgrade command
  2. Then run the discourse launcher ./launcher rebuild app
The error went away for us.
I tried a fix from a different forum. In the launcher script, I replaced:
image="discourse/base:2.0.20231218-0429"
with:
image="discourse/base:2.0.20231230-0022"
This pulls a newer image that contains rbtrace-0.5.1, which makes it work.
Got it from here: Discourse Build Error: "An error occurred while installing rbtrace (0.5.1), and Bundler cannot continue." - #50 by Neo - Discourse System Administration - Unix Linux Community.
I’m running on Oracle Linux 7.7 - old, but comparable to Ubuntu 18.04, I guess.
It would be really interesting to understand why upgrading the OS would also work, though. I always thought that Docker containers are somehow isolated from the OS, especially in this case, when it comes to Ruby gems. (I’m neither a Docker nor a Ruby expert.)
