The question is whether now that you’ve gotten there you can now upgrade to latest…
Great! But wait😅, you’re only halfway through, now you have to edit the app.yml again to version: tests-passed (and/or comment the line)
Ok, I’ll sit back down again
So add this back to where it was
#version: tests-passed
Does that look correct to you? Then save?
So done that and rebuilt.
Still saying up to date.
Maybe ive put the # in the wrong place, will try again
Nice work, @Benjamin_D! You rock. That’s great problem solving and great tutelage! You saved the day on this one.
Hopefully this should be properly resolved in the next release? DuplicateColumn and multisite:migrate failed - #7 by martin
Well, it appears not to be on the site I’m working on now.
I added some comments at FIX: Check if bookmarkable column exists before adding by martin-brennan · Pull Request #16497 · discourse/discourse · GitHub
though I think it’s some other migration that’s to blame. It seems that it’s trying to populate the fields twice, but I’m not entirely clear.
