إعادة هيكلة تثبيت الإضافة
Hi,
I noticed that public/plugins/ requires to be on a read/write mount, which is awkward as this is code under git control..
I wanted to fix that .. but I got to the part where you install plugins .. and I find that part a bit awkward… could you please (if you remember :slight_smile: ) tell me the rationale behind the plugin activation part here:
I see you first create the target dir .. then brutally clean it up .. then symlink it..
In the commit messages, I see something about not breaking Jenkins … (so possibly the rationale is stale..).
I’d be happy to try and have a stab at this… (and generally going over the whole thing making sure nothing under git control is on R/W mounts).
I think I am fine for changing it so it only does the ln if for some reason the symlink does not already exist.
Also open to committing /public/plugins/.gitignore into the repo so the folder is always there and then we can get rid of the mkdir.
This is a very very fiddly change though I am not super comfortable accepting a first time PR for it.
