Regular expression (non-English)
In a discussion about improving tag search for non-English characters in Discourse, Stranik proposes replacing a regex pattern in discourse_tagging.rb to support Cyrillic characters, initially using а-я (Russian-specific) and later {p{Cyrillic}} (more universal). The latter passes tests and works locally. Pad_Pors asks if support for other scripts like Persian and Arabic can be added. Stranik agrees it’s possible with appropriate Unicode properties. gerhard suggests {p{Alnum}} as a broader solution, but Stranik finds it fails tests unless a-z0-9 is removed — ultimately, [^{p{Alnum}}\.-_] works and passes all checks. No changes are needed in search.rb. The fix addresses a critical bug in tag handling for non-Latin scripts.
Continuation: Tag search in tags dropdown box does not work for non-English characters
file: discourse_tagging.rb
-       term.gsub!(/[^a-z0-9\.\-\_]*/, '')
+      term.gsub!(/[^a-z0-9а-я\.\-\_]*/, '')
All checks have failed
+      term.gsub!(/[^a-z0-9\p{Cyrillic}\.\-\_]*/, '')
https://github.com/discourse/discourse/pull/4886
All checks have passed
  • The construction: а-я is private (for the Russian language).
  • The construction: p{Cyrillic} (Describes many cases)
All options work on localhost
If the construction: p{Cyrillic} - Is true (and it works fine on my site), then the same will be done in the file: search.rb in the search for tags.
448 advanced_filter(/tags?:([a-zA-Z0-9,\-_]+)/) do |posts, match|
What do you think about it?
Is it possible to do this in a way that also contain other alphabets like Persian and Arabic?
I think if you change the code: p{Cyrillic}
It is necessary to find what is suitable, then yes.
I think \p{Alnum} would be the right choice.
I checked: localhost - works (As well as: а-я, p{Cyrillic} …)
But the test showed:
term.gsub!(/[^a-z0-9\p{Alnum}\.\-\_]*/, '')
Strangely (Although it already includes both letters and numbers)
delete
- a-z0-9
Can you make a correction yourself?
This bug is initially there, and working with tags is an important part.
P.S. term.gsub!(/[^\p{Alnum}\.\-\_]*/, '') - working (All checks have passed)
file: search.rb - does not need correction
