The discussion revolves around the “Remove Name Suppression on Posts” theme component, which disables the suppression of similar usernames and names on posts. The component adds a script to the <HEAD> tag to achieve this.
However, ggurbet reported that the component no longer works, despite enabling the “enable names” setting. awesomerobot suggested checking for console errors and confirmed that the component still works for them. ggurbet found some errors in the Chrome dev console but was still unable to get the component to work. ggurbet even tried manually adding the code to the header, but the issue persisted when the username and name of the user are the same.
I know this is a bit old but just to give a heads up, this does not seem to work anymore. Looked at the code of the core suppression feature but I am not sure about the mechanics here:
Also, by default it is installed as a theme instead of a component. Do you have any ideas?
I have manually added the code given by Sam to the header and tried disabling then enabling the “enable names” setting but it still does not work for me when the username and the name of the user are the same.
