Removing a user from a group with a Trust Level effect does not recompute the users Automatic Group memberships
The discussion revolves around the issue of removing a user from a group with a trust level effect not immediately recomputing their automatic group memberships. elmstedt has found that when a user is removed from a group that grants a trust level, their trust level is recalculated, but their automatic group memberships are not updated until the next system-wide recalculation event, which happens daily.
elmstedt suggests that automatic group memberships should be triggered upon removal from a group with a trust level effect or upon any change in trust level. sam agrees, stating that the fundamental dev experience is to disallow manual fiddling with automatic groups and force the use of the PUT {{site}}/admin/users/{{userId}}/trust_level endpoint to transition trust levels.
elmstedt clarifies that the API calls mentioned were recorded from the UI and not performed manually. The issue arises when a user is removed from a group with a TL3 effect, but remains in the trust_level_3 group until the next recalculation event. This is seen as incongruous, especially when using automatic trust level groups for access control.
The imagined use case is to allow a group of TL4 users to manually promote people to TL3, but the removal of a user from the TL3 effect group does not have the immediate effect of removing them from trust_level_3.
I’ve read the topic, Group trust level where it is said,
As well as this older topic, Should losing group membership unlock trust level?
Where the situation described largely meets with my experience,
But, what I have found in my own testing instance of Discourse is this…
With all Trust Level settings at default, I have a TL1 account (U) and a group named tl3 which grants Trust_Level_3.
  1. Starting conditions
    • Trust Level: 1: basic user Unlocked
    • Automatic Groups: trust_level_0, trust_level_1
    • Custom Groups: None
  2. Add U to tl3
    • Trust Level: 3: Regular Unlocked
    • Automatic Groups: trust_level_0, trust_level_1, trust_level_2, trust_level_3
    • Custom Groups: tl3
  3. Remove U from tl3
    • Trust Level: 2: Member Unlocked
    • NOTE: Despite having a trust level of 2, the user is still in the automatic group trust_level_3. With the understanding a user cannot be demoted to TL1 without a locked trust level, the expected outcome here is the user should immediately lose membership in the trust_level_2 automatic group.
  4. Lock U’s trust level
    • Trust Level: 2: Member Locked
    • NOTE: Despite having a Trust Level of 2: Member, the user is still in the automatic group trust_level_3.
  5. Unock U’s trust level
    • Trust Level: 1: Basic Unlocked
So, when unenrolling a user from a group the Trust Level is recalculated automatically and instantly, but the automatic group membership is not recalculated unless the user’s trust level experiences an unlock event.
My assumption is that automatic group memberships are computed systemwide for all users once per day and the automatic group memberships will be rectified at that point. But it feels as though automatic group memberships should be either triggered upon removal from a group with a trust level effect or triggered immediately upon any change in trust level, not just on an increase of trust level.
So the backend API call to,
POST {{site}}/admin/users/{{userId}}/groups
updates the automatic group memberships, but
DELETE {{site}}/admin/users/{{usedId}}/groups/{{groupId}}
does not, which feels like a bug, especially if you are using automatic trust level groups for access control.
And, for completeness, obviously calls to,
which are invoked when manually changing a user’s trust level in the admin interface, immediately recompute the automatic group memberships as expected.
Yeah, the fundamental dev xp thing here is that we should be disallowing this fiddling with automatic groups and force you down the route of using PUT {{site}}/admin/users/{{userId}}/trust_level only to transition stuff. Return a 422 or something if people attempt to use endpoints to manually add people to the groups or remove.
Unrolling trust level should always happen from here:
Cause that also support lock which is critical.
I get that.
I just want to be clear, all the API stuff was just seen recording the XHR stream when performing actions on group memberships through the group membership UI. I’m not actually performing these as API calls, they’re just the API calls being made when using the UI.
So, my thinking is that if there is a group with a TL3 effect, clicking this button,
Should immediately remove them from the trust_level_3 group if they do not otherwise meet the requirements for Trust Level 3 or have that trust level locked.
The imagined use case here is too allow, say a group of TL4 users to be set as owners of a group with a TL3 effect so they could manually promote people to TL3.
The promotion aspect works, but those same users removing someone from the TL3 effect group does not have the immediate effect of removing the affected user from trust_level_3.
Fully understanding this is very much an off-label use of the feature.
It just seems incongruous that a user could have a their Trust Level changed from 3 to 2 and remain in the trust_level_3 group until the next recalculation event.
