הסרת "תגיות" מתפריט המבורגר באמצעות CSS
I used this code to remove the “About” link in the hamburger menu, but I would also like to remove the “Tags” link. Removing “About” works fine, but I can’t figure out how to remove “Tags”.
// Hide About Link in Hamburger Menu
.menu-panel li a.widget-link.about-link {
  display: none;
When I inspect the tags link element in the hamburger menu, it shows:
<a class="widget-link" href="/tags" title="Tags"><span class="d-label">Tags</span></a>
I referenced this and tried writing the code in a similar way to how the “hide About link” code was written, but I cannot get it to work. I know I’m writing the code wrong, I just can’t figure out how to write it out correctly.
.menu-panel li a.widget-link[href="/tags"] {
    display: none;
Thanks homie!
I wasn’t using the [ ] brackets, that’s why it didn’t work!
Fixed.
