Bericht über Benutzerfelder?
I’ve added one User Field, editable and shown on profile. I’d like to see a list of users who have provided it, with the values. Is this possible?
I found this old topic which seems to indicate it is not, but I’m hoping there’s newer information.
Thanks!
My super-geeky workaround for now: download a backup, and grep the .sql file for “user_field_1”…
If you’re an admin, you can check this out. Lets you run queries against your db.
Thanks, the Data Explorer plugin works nicely. The query I used was:
SELECT user_id, value from user_custom_fields where name = 'user_field_1'
(though user_field_1 is particular to my site…)
