Hi - is it possible to require approval for all new topics and replies in certain categories?
Thanks so much in advance!
The discussion revolves around requiring approval for topics and replies in specific categories on a Discourse forum. cori_online asks if this is possible, and Stephen confirms it can be done via the Moderation section in category settings. cori_online reports not seeing the option, prompting Stephen to clarify the location. cori_online then reveals the version is showing as ‘unknown’ in the admin panel, raising concerns about the installation method. Stephen notes that an ‘unknown’ version suggests a non-supported installation, possibly via a third-party package, which limits support. He advises upgrading in a staging environment first to avoid risks. cori_online thanks Stephen for the guidance and plans to share it with their team.
Thanks for the speedy reply!
I’m not seeing that option in any of the Settings areas for categories…
Should it be in the ‘Security’ tab?
It’s in the Settings tab under Moderation.
OK, gotcha - if there is no ‘Moderation’ section of the ‘Settings’ tab, could that be due to not running the most current version of Discourse?
(All I see is 'EDIT PERMISSIONS")
Thank you!!!
Which version are you using if you look at /admin ?
That’s troubling to see ‘unknown’ there like that, how was the instance installed?
TBH, I don’t know - ENG team that installed Discourse initially are no longer w/ us and I am NOT an engineer ![]()
If I were to ask eng team to update platform would that help w/ this?
I honestly don’t know how big of an ask that is…
I can’t say for sure, there’s only one install method that we support here, I’ve not seen an unknown version returned with a supportable install. It’s possible you’re using a third-party package which means we’re going to be unable to help you.
Whatever you do I would recommend having a staging copy upgraded first, with no idea which version you’re upgrading from and other plugins you’re running there are just too many unknowns.
OK - thanks so much, Stephen; I’ll share this with my team.
Really appreciate the help!
