Required Tags + Allow Other Tags
Hi all,
I’m trying to create a requirement on a category where the user has to select one tag from a tag group, and then any other tags they add are free form. I thought this would be allowed via requiring one tag from my tag group and then the Allow Other Tags option. This doesn’t seem to be the case. If I enable allow other tags on top of everything else, it seems to completely remove the first requirement.
Actually, might this be a bug @team?
Are you testing this with a regular account or an admin account?
:skull:
Can I choose not to answer that question?
It’s an admin account. I thought one of my test accounts was normal for some reason. I’ll try again with de-elevated permissions in a moment.
Okay, reporting back. It works as intended for a normal user.
However, it’s not just admins that can bypass this, Moderators can as well. Is that intentional? If not, it’s a bug. If yes, I suppose I can make a feature suggestion for a setting that requires staff accounts to obey the tag rules.
It is currently how it’s supposed to work, but there is this Contribute > Feature request to change it to the way you’re suggesting:
Thanks! Will give it a look over.
