תגיות חובה אינן נאכפות עבור צוות
סיכום מבוסס בינה מלאכותית
The discussion revolves around mandatory tags not being enforced for staff members in Discourse. tvavrda reports that despite setting a tag group as mandatory, moderators and admins can still save topics without selecting a tag. Moin clarifies that this behavior is expected since staff are exempt from such rules. pfaffman expresses sympathy and suggests a site setting like staff_must_follow_tag_rules to enforce compliance. tvavrda explains their use case: using Discourse internally as a support tool where all staff are moderators, making tag enforcement crucial for consistency. pfaffman proposes a plugin to un-exempt staff and mentions the Kanban Board integration, highlighting the need for reliable tagging. tvavrda suggests a default tag feature within the required tag group, while pfaffman adds that a theme component could include a default tag in the create button.
I have a tag group which is set to be mandatory (it can be seen when entering a new topic). Nonetheless it is possible to save a new topic without a tag being set.
This is the setup:
Using 2.9.0.beta10 (afce65bb79)
Are you a moderator or admin?
אוי, אני גם וגם. אז זו תכונה, אני מניח…
Yeah. I feel your pain, though. And there’s discussion elsewhere about how it would be nice to enforce or at least warn people when they break the rules. I’d love a site setting like staff_must_follow_tag_rules.
כן בדיוק. להוביל על ידי דוגמה!
זו לא טרגדיה, אלא רק כדי להסביר את מקרה השימוש שלי.
אנו משתמשים במופע ספציפי זה של Discourse ככלי תמיכה פנימי. אז
  • כולנו מנהלים
  • הלקוחות שלנו הם משתמשים רגילים
אז בזמן שזה עובד בסדר עבור הלקוחות להזין בקשות, באגים או שאלות, כולנו, משתמשי החברה, צריכים להיזהר.
I’m using tags with Kanban Board and wish that I didn’t have to try so hard to create topics with the right tag.
The immediate solution would be a plugin that would un-exempt staff from the rules. Probably 1-4 hours work depending on features and how much testing is built in.
I believe that this comes up with some frequency, but a (very) quick search fails to find anything.
גם “תג ברירת מחדל” עולה בדעתי (בדיוק במקום שבו קבוצת התגים הנדרשת נמצאת, נוכל לבחור את ברירת המחדל).
כפי שיכולתם להבחין, קבוצת התגים שלי היא זרימת עבודה, טובה גם לקנבן. אז בדרך כלל פריט חדש יתחיל עם תג new. כך שלא תצטרכו להגדיר תג כלל.
A theme component could have a create button that would include a default tag.
