Reset my development environment, but it's stuck in read-only mode
I was running a dev environment in
~/src/discourse-1.6/
and switched over to
~/src/discourse
(Yes, I’m too stupid to actually use git, so this was my solution.)
I did
    RAILS_ENV=development
    export RAILS_ENV
    RAILS_ENV=development bundle exec rake db:drop db:create db:migrate
But now when I go to the site and try to log in I get “Login is disabled while the site is in read only mode”.
I saw something somewhere about nuking, blowing away, or resetting redis, but I can’t figure out how to go about that.
In the container, redis-cli flushall should do it, from memory.
Did the trick! That’s some memory you’ve got.
It’s my cross to bear.
