Then you’re probably going to need to use the API. Per-category posts out of context aren’t provided in a feed in this way.
I don’t understand why you can have a feed of filtered by user (/u/:username/activity.rss) but not one filtered by category ![]()
I’ll be another vote for this feature. I belong to a food discussion site http://foodtalkcentral.com/ which has 40 or so channels for discussion, most of which are region based. Living in Los Angeles I don’t have much need to see all of the posts for say the NYC channel or the Tahoe-Truckee-Reno channel but I would like to see all of the posts for the Los Angeles channel. Since there’s a lot of discussion within topics, seeing the topics is not enough. Also, setting the RSS feed for the whole board is starting to overwhelm me with posts I have no interest in seeing.
Please, enable this feature. It seems possible since, as a previous poster noted, you can have a feed filterd by user. It would be a great help. Thanks
Why not open the category-specific page for LA
If you’re logged in discourse already tracks your read state and progress within a topic.
A feed for latest replies across a category without any context would be really really confusing.
Because I prefer to read the posts in an RSS Reader rather than on the web where I have to click around to get to content. I prefer it so much so I’m using the feed for all of the board posts rather than the site even though I have to slog through a couple of hundered posts in a week. The previous site I belonged to Chowhound.com did have this feature and it made reading posts so easy.
This is usually not the case. since it is obvious what the poster is talking about. Plus topics tend to generate a lot of activity in a short period of time. In the rare instance I need context, I click through to the topic on the site.
Ich würde das auch gerne sehen.
Ich bin auf einigen Discourse-Instanzen aktiv und führe die Diskussionen in einem zentralen RSS-Reader zusammen. Eine erhöhte Flexibilität/Funktionalität von RSS-Feeds wäre sehr willkommen.
Entschuldigung, dass ich diesen Thread wieder aufwärme, aber ich finde auch, dass dies eine recht nützliche Funktion wäre, und soweit ich sehen kann, ist sie immer noch nicht verfügbar. (Neben den Beitragenden in diesem Thread siehe auch diesen anderen, neueren Thread, der ebenfalls diese Funktion anfordert)
Ein Anwendungsbeispiel ist ein Community-IRC-Kanal mit einem Bot, der bestimmte relevante RSS-Feeds überwacht und die neuesten Beiträge ankündigt. Dies ist nicht möglich, wenn der relevante Feed eine Kategorie in einem breiteren Forum ist (man betrachte beispielsweise die OpenCL-Kategorie im Khronos-Forum oder die CUDA-Kategorie im NVIDIA-Forum):
- Wenn der Bot den Kategorie-Feed verfolgt, kann er nur eine Liste von Themen erhalten: Er kann ankündigen, wenn ein neues Thema erstellt wird, aber nicht, wenn ein neuer Kommentar (Beitrag) zu einem bestehenden Thema hinzugefügt wird, was die Nützlichkeit des Bots erheblich einschränkt;
- Wenn der Bot den forumweiten
latest.rss-Feed verfolgt, erhält er Beiträge aus allen Themen, einschließlich solcher aus irrelevanten Kategorien, und müsste eine zusätzliche Filterung vornehmen, mit dem Risiko, Updates zu relevanten Beiträgen in einer wenig aktiven Kategorie eines ansonsten hochvolumigen Forums zu verpassen (außer vielleicht durch Abfragen in hoher Frequenz, was nicht ideal ist).
Ein Kategorie-Feed, der sich auf die neuesten Beiträge in dieser Kategorie konzentriert, würde dies lösen. Dies könnte entweder ein Feed für die „neuesten Beiträge in dieser Kategorie
Wenn benutzerdefinierter Code, der auf allen Discourse-Foren des Bots funktioniert, eine Option ist, können Sie stattdessen /posts.json abfragen; jeder Eintrag enthält eine category_id, nach der Sie filtern können.
Wie oben erwähnt, ist das Hinzufügen eines posts.rss zu jeder Kategorie möglich, wurde jedoch bisher noch nicht umgesetzt.
Es würde die angebotenen RSS-Feeds sicherlich schön abrunden.
Ich habe im Moment persönlich keinen Nutzen dafür, aber ich sehe, dass es in einigen verschiedenen Umständen hilfreich sein kann.
Im Moment kann dasselbe mit einem Drittanbieter-Integrationsdienst ziemlich einfach erreicht werden (d. h. make.com, zapier.com usw.), aber es ist etwas unordentlich.
