هل توجد طريقة لإعداد منتديات متعددة ضمن نفس النطاق؟
أنا أطلق منصة ستستضيف منتجات متعددة، لذا أرغب في فصل منتديات كل منتج مع الحفاظ على نفس النطاق.
شكرًا لك!
شكرًا لك!
A couple possibilities I can think of. Depends if the products are actually related / have lots of overlapping users, vs. if they’re e.g. totally separate user groups but the forums just happen to be owned by the same parent company.
If they’re related, could make sense to have each product as a category, and use subcategories under those. Could use category permissions so only certain people see certain top level product categories.
Or if you want them as totally distinct forums, probably best to install each forum on a separate subdomain. You wouldn’t have to buy extra domain names but each forum would be separately installed on a subdomain so you’d have e.g. product1.maindomain.com, product2.maindomain.com, and product3.maindomain.com. You could add some kind of shared menu if you want them separate but still interlinked in some way.
For more specific advice would be good to have more detail on what exactly you’re looking to do in terms of how these forums relate to each other, who the users are, etc.
Hi @bts, thanks for the response.
It’s a gaming platform and we will have different games in different languages, so even though some users could overlap on multiple games, we need features such as the “Latest messages”, “Pin Globally” and “Pin Banner” to be exclusive to the forums themselves.
For example, if game 1 is available in language A and game 2 is available in language B, we don’t want global announcements for game 1 to show up in game 2’s forum as it won’t have any relevancy.
That being the case, would this suggestion be the path?
product1.maindomain.com,product2.maindomain.com, andproduct3.maindomain.com. You could add some kind of shared menu if you want them separate but still interlinked in some way.
Do you mean de.yourdomain.com, en.yourdomain.com and so on? (or en.game1.yourdomain.com?) I don’t know how it would even be possible to have forum.yourdomain.com somehow be different if someone is thinking of a different game.
If it’s really language that you care about, you could have one forum and have people join a group to gain access to categories in whatever language (and game) that they like. It’s a bit confusing because they’d have to know to join the right group, but you could conceivably work that out, especially if all categories required group membership. (But if you did that, then Google couldn’t index anything)
We have experience hosting forums for big game franchises and we recommend doing one instance per locale/game.
Eg:
That way you can scale instance resources according to how popular is each game in each language.
That is good, but expensive.
For companies with smaller budgets it might be OK to start with categories for different games, and subcategories for language within the games.
مرحبًا @Falco
أنا أقرأ هذا المنشور القديم وأهتم أيضًا باستضافة شيء مماثل، لكنني أريد التأكد من أن هوية المستخدم واحدة عبر منتديات متعددة.
ما يعجبني في منتدى Discourse هو أن الفئات المختلفة يمكن أن تظهر في الصفحة الرئيسية مع صورة ووصف وعدد من المواضيع المدرجة (الأعلى/الأحدث) (في عرض الهاتف المحمول، هل يمكن فعل ذلك أيضًا على سطح المكتب؟ لا أرى هذا الخيار كإمكانية). ومع ذلك، عند إنشاء فئات فرعية وعند التنقل إلى الفئة الأصلية، تُعرض جميع المواضيع معًا وتفقد تلك الفئة الشاملة مع وصفها وقائمة مواضيعها.
سؤالي هو: أي مما يلي يمكن استضافته ذاتيًا؟
ParentCategoryA.discourse.example.com منتدى منفصل يناقش الفئة الأصلية AParentCategoryB.discourse.example.com منتدى منفصل يناقش الفئة الأصلية Bdiscourse.example.com/supercategoryA مع جميع الفئات ذات الصلة بالفئة العليا Adiscourse.example.com/supercategoryB مع جميع الفئات ذات الصلة بالفئة العليا Bشكرًا مقدّمًا
