Rake spec parallel uitvoeren
By chance has anyone already running the rake spec tasks in parallel?
https://github.com/grosser/parallel_tests
We run our tests in parallel during CI, and also during local development. To try it out, you can run:
bin/rake parallel:create
bin/rake parallel:migrate
bin/turbo_rspec
Thank you, this is pretty cool!
To make it run in my local dev environment I first had to fix:
ERROR: permission denied to create database
Tasks: TOP => db:create
PG::InsufficientPrivilege: ERROR:  permission denied to create database
Couldn't create 'discourse_test_32' database. Please check your configuration.
rake aborted!
ActiveRecord::StatementInvalid: PG::InsufficientPrivilege: ERROR:  permission denied to create database
Caused by:
# switch into container
d/shell_root
# inside container - root@discourse:/#
sudo -u postgres psql
# psql - postgres=#
ALTER USER discourse CREATEDB;
exit
exit
And now it works even inside the container:
d/rake parallel:create
d/rake parallel:migrate
d/exec bin/turbo_rspec
Finished in 3 minutes 11.6 seconds (files took 0 seconds to load) :rocket:
16015 examples, 12 failures, 10 pending, 3 errors occurred outside of examples
