rocher
(admin)
January 10, 2026, 2:41pm
1
Successfully uploaded to cloud storage vendor Qiniu Cloud, the loaded link is: https://img.i4ta.com/original/1X/5be788f6a5e3d0efa278e1e87b6c6ca6be2ce4cf.mp4 , and the browser prompts:
"error": "download token not specified"
The video loaded in the topic:
<video width="100%" height="100%" preload="metadata" controls="" style="display:none">
<source src="https://img.i4ta.com/original/1X/5be788f6a5e3d0efa278e1e87b6c6ca6be2ce4cf.mp4">
<a href="https://img.i4ta.com/original/1X/5be788f6a5e3d0efa278e1e87b6c6ca6be2ce4cf.mp4">https://img.i4ta.com/original/1X/5be788f6a5e3d0efa278e1e87b6c6ca6be2ce4cf.mp4</a>
</video>
Is it not using private bucket authentication? But I don’t know where to configure it. Are there any experts who know how to solve this?
Lilly
(Lillian )
January 10, 2026, 2:59pm
have you read this topic?
This topic covers how to configure some common S3 compatible Object Storage providers (S3 clones). See Set up file and image uploads to S3 for more details about Amazon AWS S3 configuration, which is officially supported and used internally by Discourse for our hosting services.
Provider
Service Name
Works with Discourse?
Amazon AWS
S3
Yes
Digital Ocean
Spaces
Yes
Linode
Object Storage
Yes
Google Cloud
Storage
Yes
Scaleway
Object Storage
Yes
Vultr
Obj…
I don’t know anything about Qiniu Cloud or if their S3 storage is supported, but you will need an access key and token (I believe they are generated in your Qinui Cloud console). If it’s possible, your app.yml file settings should probably look something like this example :
## S3 storage
DISCOURSE_USE_S3: true
DISCOURSE_S3_REGION: whatever
DISCOURSE_S3_ENDPOINT: http://s3-ap-southeast-1.qiniucs.com
DISCOURSE_S3_ACCESS_KEY_ID: *************
DISCOURSE_S3_SECRET_ACCESS_KEY: *****************
DISCOURSE_S3_CDN_URL: http://qiniu.pengfeima.cn
DISCOURSE_S3_BUCKET: qiniu-s3
DISCOURSE_S3_BACKUP_BUCKET: qiniu-s3/backups
DISCOURSE_BACKUP_LOCATION: s3
pfaffman
(Jay Pfaffman)
January 10, 2026, 11:50pm
3
Indeed https://img.i4ta.com/original/1X/5be788f6a5e3d0efa278e1e87b6c6ca6be2ce4cf.mp4 gives that error. You’ll need to check somewhere that people know about your to configure i4ta. I’m pretty sure that it has to do whey the configuration there.
rocher
(admin)
January 11, 2026, 2:11am
4
Yes, I installed it via docker-compose, and I have configured the AK and SK in the Discourse backend, and I can successfully upload files. The only issue is that I cannot view them. I have checked all possible configurations and haven’t found where to configure adding the token to the CDN link when accessing it. Since this storage is private, the token must be included. Are there any other places besides the configuration you mentioned above?
rocher
(admin)
January 11, 2026, 2:14am
5
Here is my configuration, is it correct? Are there any other related configurations needed?
pangbo
January 11, 2026, 6:54pm
6
If your S3 bucket is private, you need to enable the Secure uploads option, otherwise Discourse will not attempt to sign attachment links.
After changing this setting, you must rebake the post for it to take effect.
Added in the Discourse 2.4 release in February is the Secure Uploads feature, which provides a higher degree of security for ALL uploads (images, video, audio, text, pdfs, zips, and others) within a Discourse instance.
Prerequisites
You must have S3 uploads enabled on your site, which needs the following settings to be filled:
S3 access key id
S3 secret access key
S3 region
S3 upload bucket
You also must be using an S3 bucket that does not have a Public bucket policy, and you need to make su…
rocher
(admin)
January 19, 2026, 12:15pm
7
pangbo:
Secure uploads
Thank you very much, it was indeed the effect of this setting, it has troubled me for a week, thank you very much for your help~
