Search a huge topic for shield logo to find posts made by staff
סיכום מבוסס בינה מלאכותית
Searching for Staff Posts in a Huge Topic
Jan_Polet inquired about searching a large topic for posts made by moderators or staff members, specifically looking for the shield logo.
tshenry suggested two alternatives:
  1. Check the “Activity” tab of the staff or moderators group to see all posts made by its members.
  2. Click on a staff member’s avatar and select “posts in topic” to view their contributions within the topic.
robmc further refined the second suggestion, recommending to:
  1. Click “Summarize this topic” to view the most important contributions, which may include official answers from staff.
  2. Expand the summary to identify major respondents and filter by their contributions using the method suggested by tshenry.
Is there a way to search a topic for the shield logo to find posts made by moderators or staff members?
Sometimes, especially when a topic is huge, I just want to scan the official answers.
If that isn’t possible, is there another way to filter posts made by the staff?
Discourse is getting more and more advanced, so I hope there is a way.
Thanks!
Jan
I don’t think there is currently a way to do what you describe. There are two decent methods I can think of to narrow down posts from specific users:
  1. Go to the “staff,” “moderators” or any group you are interested in and click the Activity tab to see all posts made by the members of that group. Unfortunately, it’s not a solution on the topic (=thread) level, but it does at least isolate those users.
  2. The other option that does work within the context of a topic is to click on the avatar of the user you are interested in and then select the button you see in this screenshot that says “84 posts in topic.” This will only show the posts in the topic from that user.
As a refinement to this excellent suggestion, you can click on the box at the end of the OP
You can click on Summarize this topic to get the most important contributions (not just staff though) and if these are ‘official answers’ they may well appear on this list
Then if you expand it you can see the list of contributors to identify the major respondents, then do as @tshenry suggests and filter by their contributions alone
