Zoeken naar status:onopgelost retourneert onderwerpen uit categorieën waar oplossingen niet zijn ingeschakeld
A bug was reported by dandv where searching for status:unsolved returns topics from categories that do not have Solved enabled. pmusaraj confirmed this as a bug, stating that the search should only list topics in categories where topics can be marked as solved. A fix was implemented by Juan_David_Martínez and confirmed by pmusaraj to be working as expected.
Our forum has allow solved on all topics disabled, and the Support category with Solved enabled and the drop-down filter working correctly.
The problem is that a search for status:unsolved still includes results from categories that have Allow topic owner and staff to mark a reply as the solution unchecked (for instance Showcase where “Solved” doesn’t quite make sense).
Is this a bug? Should that query only show unsolved topics across categories that have Solved enabled, but instead it looks for the absence of the “solved” attribute?
(As a workaround I tried searching for status:unsolved #support #general, these being the categories that might have Solved on, but that returned zero results because searching across categories isn’t implemented yet.)
Yes, I think you’re right, this is a subtle bug. When searching for status:unsolved, we should only list topics in categories where topics can be marked as solved.
We will work on a fix over the next few weeks.
This should be fixed now @dandv, per FIX: Search bug for status:unsolved returns topics from non-solution … · discourse/discourse-solved@4032a1e · GitHub, thanks @Juan_David_Martínez for the fix.
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
