Allow searching across multiple categories
I’m trying to do a search across multiple categories like:
category:10,11,12 but it seems to use only the first one.
Am I missing some syntax? I presumed the same as for tags?
Unfortunately you cannot search across multiple categories, this is only supported for tags. I will move your topic to Contribute > Feature, as it is a reasonable request.
Thanks David, I wonder if for time being it then would be ok to just append it as local href:
search?q=status%3Anoreplies%20after%3A7%20-tags%3Aknowledge-base%20in%3Aunseen%20order%3Alatest
Wanted to add this would be handy for us too.
Searching across categories would provide a workaround for finding unsolved topics in more than one category. Searching for status: unsolved returns unwanted results because it includes topics that don’t have Solved on.
This will be possible with the new filters. :partying_face:
Still experimental though, but live on Meta if you want to give them a try. :+1:
This topic was automatically closed after 37 hours. New replies are no longer allowed.
