See who marked post as solved?
In a discussion about whether admins can see who marked a post as solved, AlexBCodecademy initially asked for visibility into this action. Yuun noted that the poster whose reply is marked solved receives a notification, and admins could check those notifications, though no public in-thread display exists. AlexBCodecademy clarified they wanted this visibility as an admin only, not for end users. strager questioned whether users should know which posts are marked solved by moderators or admins, suggesting potential misuse of such information. AlexBCodecademy reiterated the request was for admin-only access. Mittineague and cpradio confirmed only the topic’s original poster (OP) and staff can mark posts as solved. erlend_sh pointed out the inconsistency in keeping this information private, since liking a post — a similar action — is public. AlexBCodecademy agreed, concluding they’d be happy if at least OPs and high-trust-level admins could see who marked a post solved. cpradio added that the solved plugin likely already tracks this data, making implementation feasible. Mittineague referenced code logic suggesting the plugin must track this to function correctly, and shared a link to related documentation.
Is there a way to see who exactly marked the post as “solved”?
Thanks!
「いいね!」 1
Whoever’s post is marked as a solution gets a notification with this info on it - as an admin you could just check their notifications.
I don’t think there’s a public, in-thread display of this info though, which could be an area for improvement. At least if the expectation is that someone other than the topic creator is regularly marking posts as solved.
「いいね!」 2
I would love to (as an admin) be able to see who marked it as solved without having to dig for notifications.
「いいね!」 1
As an admin I could see the uses for this, but do you really want your end users to know which posts are marked as solved by the user and which by your moderators/admins? Sometimes too much information can be a bad thing.
「いいね!」 1
No, that’s not what I am suggesting. I am suggesting that the admin is the only one who can see who marked as resolved.
「いいね!」 1
Isn’t it only the topic’s OP that can mark a post as the Solved post?
「いいね!」 1
And staff (IIRC)
「いいね!」 2
It’s a weird thing to be secretive about though. Marking a post as solved is closely related to Liking a post, and the latter is always public. Similarly, on StackExchange you know that the post marked as the solution was marked as such by the Original Poster, so we’re used to this info being transparent.
「いいね!」 2
That’s true! Great point. I was only thinking as an admin :wink: So I don’t care either way, but I would love in the very least, at least admins (high trust levels) and OP’s to be able to!
「いいね!」 1
I definitely don’t mind such a feature either. Probably isn’t terribly difficult either. As I’m sure the solved plugin knows who marked one of the posts as solved.
I think it must how else could the Helpdesk Badge be granted?
https://meta.discourse.org/badges/125/helpdesk
eg. it tests for the OP
var isOp = User.currentProp("id") === this.get('post.topic.user_id');
「いいね!」 4
