Can we use firebase as hosting options.And what are the best hosting options aws and google cloud.
Thank for replying but the guide doesn’t tell anything about firebase as a options and also not included the google cloud. I understand that these may not be the best options but I want to know that can we use them or not.
Our official install guide lists the requirements to host Discourse. If Firebase supports the listed requirements and allows SSH access, it can run Discourse:
- modern single core CPU, dual core recommended
- 1 GB RAM minimum
- 64 bit Linux compatible with Docker
- 10 GB disk space minimum
I added this section:
IIRC Firebase hosting is serverless, so it won’t work with Discourse.
