I enabled ai embeddings semantic quick search enabled but it gives error 500. It works here, and error 500 quite often happends because of issues of servers, aka. at my end, but I’m a bit lost how to start solving out this.
I upgraded a couple days ago, but it hasn’t work ever. Sementic suggestions works just nice when searched as usual.
Used model is GPT-4 Turbo, and embeddings model is text-embedding-3-small — if that matters. I used large at some point, but changed it to small, because I didn’t get wanted results, and at that point OpenAI has some issues with large-model.
Safe-mode doesn’t help.
And error I get:
Message
Failed to process hijacked response correctly : ArgumentError : address cannot be nil or empty
Backtrace
/var/www/discourse/lib/final_destination/http.rb:5:in `connect'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:1580:in `do_start'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/net-http-0.4.1/lib/net/http.rb:1569:in `start'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:112:in `request_with_wrapped_block'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:102:in `perform_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/adapter.rb:45:in `connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-net_http-3.1.0/lib/faraday/adapter/net_http.rb:65:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/rack_builder.rb:152:in `build_response'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/connection.rb:444:in `run_request'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/faraday-2.9.0/lib/faraday/connection.rb:280:in `post'
/var/www/discourse/plugins/discourse-ai/lib/inference/hugging_face_text_embeddings.rb:50:in `rerank'
/var/www/discourse/plugins/discourse-ai/lib/embeddings/semantic_search.rb:136:in `quick_search'
/var/www/discourse/plugins/discourse-ai/app/controllers/discourse_ai/embeddings/embeddings_controller.rb:62:in `block in quick_search'
/var/www/discourse/lib/hijack.rb:64:in `instance_eval'
/var/www/discourse/lib/hijack.rb:64:in `block in hijack'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/concurrent-ruby-1.2.3/lib/concurrent-ruby/concurrent/promises.rb:911:in `callback_on_resolution'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/concurrent-ruby-1.2.3/lib/concurrent-ruby/concurrent/promises.rb:797:in `call_callback'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/concurrent-ruby-1.2.3/lib/concurrent-ruby/concurrent/promises.rb:803:in `call_callbacks'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/concurrent-ruby-1.2.3/lib/concurrent-ruby/concurrent/promises.rb:692:in `resolve_with'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/concurrent-ruby-1.2.3/lib/concurrent-ruby/concurrent/promises.rb:1325:in `resolve'
/var/www/discourse/lib/scheduler/defer.rb:115:in `block in do_work'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-6.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-6.0.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/lib/scheduler/defer.rb:109:in `do_work'
/var/www/discourse/lib/scheduler/defer.rb:97:in `block (2 levels) in start_thread'
Env
HTTP HOSTS: foorumi.katiska.eu
Ideas?
