Serveral issues after upgrade from beta7 to beta9
  1. whenever i post a reply, the replybox doesnt disappear only the left side gets empty. It doesnt disappear until i reload the page.
  2. i no longer can use the edit function on topic titles or posts - nothing happens when clicking on it. Same for all other funtions there like sharing, liking, flagging, collapsing menue, etc.
  3. All Youtube video links disappeard on every post.
I reproduced the issues on opera and firefox.
The update worked like a charme as always with no errors.
What can i do?
Can you upgrade to latest
I already did, scince then these bugs appereared
but i skipped the update beta 8
Do you have any plugins installed?
all classics plus replygif which i doesnt use
when i do updates i always start with the plugins (most time tagging plugin) and then update whole discourse
Can you rebuild the container ?
Ok after rebuild issue 1. and 2. seem to be solved but issue 3. is still present.
Remove replygif which is broken, rebuild and try again.
Are the same one boxes working here?
ill try
I removed the replygif plugin from the app.yml file, rebuild the container and everything works fine now :smiley:
thanks @sam
