Set calendar start day in personal preferences
סיכום מבוסס בינה מלאכותית
The discussion revolves around setting the calendar’s start day in Discourse’s personal preferences, sparked by erlend_sh who mistakenly selected wrong dates due to Sunday being the default first day. Many users, including tophee and j.jaffeux, advocate for Monday as the start day, citing ISO 8601 as the international standard. codinghorror and sam question the need for a user setting, preferring to follow a standard rather than add complexity. dan submitted a PR to allow any day as start day, but later clarified that Monday is already the default in Pikaday, the calendar library used. erlend_sh supports sticking to the standard over adding a personal setting, suggesting such granularity could be handled via a plugin. sam ultimately closes the PR, deeming a user setting excessive for the benefit. Later users boospy and josy38 inquire about configuring Monday as the start day, indicating the feature may no longer be visible or accessible in current versions.
Continuing the discussion from Discourse-chronos :globe_with_meridians: :timer_clock::
I recently set the wrong date when I blindly selected what I thought was Wednesday and Thursday, not realizing the calendar’s week started with Sunday.
How about a personal preference setting for this, like most digital calendars have?
Alternatively just start with Monday because logic :squinting_face_with_tongue::call_me_hand:
10 לייקים
I have no idea what is more common here as far as days of the week to start with on the far left, but presumably the actual numbers on the days would have been a clear indicator of what date was selected?
Thanks for bringing this up. It happens to me all the time on US based apps. I then routinely contact support to ask them whether they would consider allowing users to select Monday as first day of the week. If they don’t and its an app where you dates are important I’ll sign off. It’s just too much to keep in mind when scheduling stuff.
And international standard.
2 לייקים
If there is an international standard we should use that rather than adding Yet Another Preference.
3 לייקים
ISO 8601
2 לייקים
Being 'murican I’m used to calendars having Sunday as the leftmost column. But I’m not sure rearranging columns is the only approach. I have seen calendars where the weekend days had a slightly different background color even when Sunday was leftmost and Saturday was rightmost. Would that not be enough of a visual cue for those accustomed to having Monday as the leftmost column?
3 לייקים
I would go with Monday and follow the standard instead of adding a setting too.
13 לייקים
In my experience that doesn’t work. I guess either your blindly doing routine work and then those shaded backgrounds wont change your state of consciousness or you’re alert and then you’ll notice anyway.
I’m all for following international standards but will this not simply reverse the problem? Or are “'muricans” more flexible than the rest of the world when it comes to calendars? Perhaps you’re used to switching between formats? In that case, I guess it’s fine to follow the standard.
But when it comes to date formatting more generally, I suppose you’ll be more reluctant to switch to international standard for the en locale, right?
לייק 1
I’m not 100% for forcing anything but if we don’t have a setting and can’t fully rely on locale detection which is the root issue here (erlend uses english but doesn’t expect american date format), then, I would follow the standard.
4 לייקים
Hi @erlend_sh,
I noticed that Monday is already the start day for Pikaday (library used for calendar widgets). Could you tell me in which part of Discourse have you encountered Sunday as a first day?
Anyway, I started working on this and already submitted a PR for it here.
Currently, you can actually choose any day of the week as a first day, which is silly, but I will change that as soon as I am sure that all relevant places have been touched.
7 לייקים
I was referring to our “Insert date” feature in the editor.
Thanks for the PR! Keep in mind it’s still unclear whether we want to allow this as a personal setting as opposed to just sticking with the most prevalent standard.
I’m in favor of the latter. The setting could be extracted to a very trivial plugin suitable for niche communities where this granularity is somehow important.
3 לייקים
Oh, okay. For me the starting date is Monday and I found it weird that it was not Sunday, but then I noticed that @j.jaffeux has made a commit changing that.
Oh … so this is all done now? I am so sorry, going to close that PR, I just feel that adding a user setting here is just way too big for the benefit we get.
5 לייקים
Don’t worry, Sam. At least now if anyone needs it, they can apply the patch themselves. :slight_smile:
2 לייקים
Hello all :slight_smile:
in actual discourse version i can’t find this settings anymore. Has it been moved? We would have liked to configure Monday as the first day of the week.
Hi
i’ve got the same Problem - how can i set Monday as Start of the Week?
