Setting to manually close AI Helper's popup modal
A user MachineScholar reported a bug where the AI Helper’s popup modal in the browser automatically closes when trying to select text, affecting Chrome (Windows) and Safari, though it works fine on mobile. They requested a setting to manually close the popup via an ‘x’ to avoid this issue. keegan acknowledged the issue, moved it to the bug category, and confirmed a fix was implemented in pull request #1221. MachineScholar confirmed the issue was resolved.
My users have noticed that the AI Helper’s popup box is a bit finicky when it comes to trying to select text within it. Sometimes they only want to select a portion of it (as opposed to using the copy button) yet it seems to be slightly buggy and automatically closes itself whenever they try to highlight text. This happens on Chrome browser (on Windows) and on Safari, however it works perfectly fine on the iPhone/iPad app.
Hence, my feature request:
Could we get a plugin setting which gives us the option to force the user to have to manually close the popup, for example via an “x” in the corner or something like that? It would completely sidestep this issue! :grinning_face_with_smiling_eyes:
Other than that, everyone is in love with the AI Helper so splendid work!
Thanks for the request! I’ve moved this to Contribute > Bug, because we do want it selectable always. A setting won’t be necessary here.
I pushed out a fix:
This should now be working:
Perfect! All fixed up!
This topic was automatically closed after 2 days. New replies are no longer allowed.
