Setting to only let staff upload media/attachments
Is it possible yet to allow only staff or moderators to upload pictures? If not, it should be done. I have 20Gb free space on my server, for big community it’s like a month or two to fill. Especially if there’s gonna be 31 megabyte gifs! So I disabled uploading for now (except avatars), but I need my staff to have this feature. Because they create important topics and I don’t want pictures to be missed from there. And I don’t give a care about pics in regular users junk-topics - yes. :troll:
3 إعجابات
Totally offtopic: Please write more explanative titles, “Only staff can upload” does not give the reader an overview of what your feature is. (I edited the title.)
إعجاب واحد (1)
Sorry, that’s language barier (let’s call it accent). :slight_smile: If I’ll try to write longer topic names, there’s gonna be grammatical mistakes, so someone will have to edit them anyway. But I’ll try my best.) And if I’ll fail, Yoda on my avatar put I will.
4 إعجابات
I’d really like to see that, too, but in a generalized version: There should be additional file types that staff users only may upload. This solves your problem (you can say that users may not upload any file type, while staff may upload images), but also the problem that you might want to allow uploading more dangerous file types (say .js) by staff (without an admin doing the enable setting—reload site—upload file—disable setting dance).
إعجابَين (2)
So two site settings, one for users, the other for staff? What would the default values be? I wonder if it should only apply to admins since many sites don’t trust their moderators that much…
إعجاب واحد (1)
Sounds good!
I’d say:
Default for users: Keep the current default.
Default for additional filetypes for staff users: None.
In addition, I’d completely exempt admins from the check.
This means that…
  • The defaults don’t change for non-admins.
  • Admins can upload anything (which they already could do anyway, but with less comfort).
  • If you want to allow moderators to upload additional file types, you can use the second setting for that.
  • If you want to restrict image upload to staff only, you can remove all filetypes from the user-setting and add image files to the staff-only setting.
4 إعجابات
Seems like a good idea! @techapj can you add this to your list, low priority?
3 إعجابات
OK pr-welcome for a new site setting that allows staff extra filetypes.
additional filetypes for staff users default none
Watch out though cause you need to flow the info back into the client so it allows staff to select this stuff.
5 إعجابات
Since you’re at it, a special file size limit for staff, larger than for users, will be great.
You don’t want users to be uploading 20megapixels photos, but staff should know what they are doing.
I’ve got a PR for this :smile:
11 إعجابًا
