(Simultaneous) file uploads limit
Hi guys,
I have tried to upload a couple screenshots, but then it showed me that I am not able to upload more as 5 files at once.
Sorry, you can only upload 5 files at a time.
So far as I remember was it possible to upload more files at the same time before.
Did this change with one of the last recent updates?
I found out, that it is the simultaneous uploads option which creates this limit, but this option setting is also limited to a maximum of 20.
Why is it actually not possible to set the simultaneous uploads option higher as 20?
Thanks
Michael
Any idea how to change that value to more than 20?
So far I remember was there no (or a much higher) limitation before.
Set it to 0 for unlimited. :wink:
