Site fails to load with js errors
Our site (https://talk.remobjects.com/) started failing to load with the last few updates:
Laden voor het <script> met bron ‘https://talk.remobjects.com/assets/ember_jquery-27e777857b8c0730dacfe09cb11711365d21a5db4f9ee0b85d494e4259cf6cda.js’ is mislukt. [talk.remobjects.com:34](https://talk.remobjects.com/)
ReferenceError: define is not defined[Meer info] [_preload-store-ec90ffab9d7a6d9e507dda7cf7343e9d50b8bce624f7f44486ac8fd6b9814309.js:1](https://talk.remobjects.com/assets/_preload-store-ec90ffab9d7a6d9e507dda7cf7343e9d50b8bce624f7f44486ac8fd6b9814309.js)
Laden voor het <script> met bron ‘https://talk.remobjects.com/assets/vendor-20c2f328b5abb11fe184c1b75687e13d2b1ecc3ef8c7a3340da616da2acb03bb.js’ is mislukt. [talk.remobjects.com:38](https://talk.remobjects.com/)
ReferenceError: define is not defined[Meer info] [_pretty-text-bundle-d8a2e94eb658e9772d1ffdfcc0c3c5d31eba61f2c36e5f86a0d59f2d76e795ba.js:1](https://talk.remobjects.com/assets/_pretty-text-bundle-d8a2e94eb658e9772d1ffdfcc0c3c5d31eba61f2c36e5f86a0d59f2d76e795ba.js)
ReferenceError: define is not defined[Meer info] [application-faebd89d087a88aed7d48f6dd6c16a4721027e95b7da1fc6db583719d0ada076.js:1:1](https://talk.remobjects.com/assets/application-faebd89d087a88aed7d48f6dd6c16a4721027e95b7da1fc6db583719d0ada076.js)
ReferenceError: Ember is not defined[Meer info] [plugin-ece81ae2de07f89c2a2358bde79f6a75a400c536bb254955ee48ee6a2c35860c.js:1:1](https://talk.remobjects.com/assets/plugin-ece81ae2de07f89c2a2358bde79f6a75a400c536bb254955ee48ee6a2c35860c.js)
ReferenceError: define is not defined[Meer info] [_plugin-third-party-95176350723c7352bf3851c4a776723ad45db51c33dd061787efcc6dc0177e89.js:1](https://talk.remobjects.com/assets/_plugin-third-party-95176350723c7352bf3851c4a776723ad45db51c33dd061787efcc6dc0177e89.js)
ReferenceError: define is not defined[Meer info] [_admin-df2063af5c4693fff66917c700756e4fd7644887948651199a4c0398445a012b.js:1](https://talk.remobjects.com/assets/_admin-df2063af5c4693fff66917c700756e4fd7644887948651199a4c0398445a012b.js)
ReferenceError: require is not defined[Meer info] [talk.remobjects.com:435:13](https://talk.remobjects.com/)
ReferenceError: Ember is not defined[Meer info] [talk.remobjects.com:452:3](https://talk.remobjects.com/)
Tried updating again but that didn’t make any real difference. What else can I try?
The site itself does function fine in already opened tabs.
Try safe mode:
If that works, then the problem is being caused by one of your themes or plugins
Thanks; that gives the exact same result:
I think the next thing to try would be a command-line rebuild, assuming you have a standard self-hosted installation.
I’m seeing this in Chrome:
I remember reading that SPDY errors have something to do with SSL / https or things along that nature, I could be wrong though.
Thanks! Chrome gave a better hint there (the weird thign was, if you load those urls manually they’re fine, if you let the browser load them, it doesn’t work). turns out my disk was full for the outside nginx; a cleanup made it work.
