Sito offline dopo il backup
Hello,
I took backup, now my site down. What may be possible reason?
Cloudflare said - Connection timed out. So, I disabled Cloudflare.
Now, Browser says - This site can’t be reached
Thanks & Regards,
Gulshan
Possible things that might be wrong.
Is there anything in the logs?
Have you tried restarting discourse?
Is the backup still going on?
Please see, this is from admin/backups/logs page.
https://dl.dropboxusercontent.com/s/kyn77h5sybi41xn/backup-logs.txt
How to do that? Please tell me.
I guess, no. Just site went down.
Are you using some kind of discourse hosting provider by chance?
Before site went down - I received “The backup was successful.” message.
Site went up, now after few minutes (approximately 12 minutes)
I see site is up automatically, and again I received same push notification that “The backup was successful.”
Can you tell us what kind of setup you are using?
  • Communiteq (formerly DiscourseHosting)?
  • self-hosted?
  • are you using pgbouncer?
I am using self-hosted.
you should be able to restart it by sshing into the server where discourse is being hosted and cd into /var/discourse. if discourse is installed elsewhere than cd into where its installed
run this to restart discourse
sudo ./launcher restart app
app may or may not be the name of the discourse image. just replace it with whatever you used.
Now it is up. Sorry, in bit hurry up panic moment, I wrote down, instead of up.
Now it is okay. Thanks for the response.
I also received today Upgrade message, should I do? Will I have to face any downtime?
to upgrade just goto /admin/upgrade and click upgrade.
Downtime is minimal.
Is this process automated like we do in WordPress? or I have to do anything extra after clicking on Updrade? I am afraid.
its almost entriely automated. there is one extra click that just confirms that you want to upgrade
there is no need to worry. Nothing should go wrong
