šŸ™‚ Ɖmoji dans le titre et les URL
Hi,
I like to add emojis in titles, but after an emoji is added, the url of the post also changes, including the name of the emoji.
For example, if I add the :smile: emoji, the url changes:
Before: www.example.com/t/nice-title/25
After:  www.example.com/t/smile-nice-title/25
This is bad for SEO. Is there anyway to manually edit the URL or to avoid having URLs with emojis?
Thanks!
I’ve just added a emoji to the title of this post, and the url didn’t change. :slight_smile:
How do I achieve this in my installation?
I don’t think removing the emojis from the url is a possibility just yet, but I could be wrong.
While I understand you want to keep the emojis but remove them from urls, if that bothers you so much, you can remove / disable them altogether.
There was a bit of discussion about this here:
Which resulted in a setting to disable emojis in topic titles if that’s what you prefer:
Thanks! I understand.
Anyway, there must be a way to add an emoji in the title, and not change the URL, since in this forum https://meta.discourse.org/ , if you add an emoji in the title, after the post has been created, the URL doesn’t change.
In my install, if I add an emoji to the title, after the post has been created, the URL does changes.
You’re right, I just saw your second post. I will leave this to someone more knowledgeable to answer :sunflower:
It’s different if you add the emoji as :) or if you add it as :slightly_smiling_face:.
First isn’t added to the URL, while the second will be.
Both URLs will work, and we have a canonical pointing to the, well, canonical URL.
Thanks. Anyway, I think I found an easy solution to my need. I hope this helps someone else:
1- Go to a page containing an unicode list of emojis, like https://emojipedia.org or http://xahlee.info/comp/unicode_emoticons.html
2- Copy your emoji and paste it in the title šŸ’· šŸ• šŸ’… šŸ’·.
It will still appear in the title but not in the url. You can use many emojis šŸ’· šŸ• šŸ’… šŸ’· :pound_banknote: :dog: :nail_polish: :pound_banknote:, and not only the basic ones, like :) :(
Note: in the editor and in the preview, they are showing if firefox, but not in chrome browser at least in my computer
@codinghorror this is a bit of a strange inconsistency here, I don’t really mind it that much but you can work around emojis sneaking into slug now by having actual emojis in the title vs :smile: and such.
We need to stop doing this because it hurts non English sites a lot, as previously discussed.
Should we strip emoji from slug unconditionally or just for non-English sites, @techAPJ worked on this last so he can do whatever you think is right here.
For parity with other languages I think we have to strip emoji strings from URLs / titles @techapj – otherwise it is a giant can of :bug:s to untangle that :bug:
The other option is to keep unicode emoji in URLs but do we really want to go there?
http://ā˜ā†’ā„ā†’ā˜ƒā†’ā˜€ā†’ā˜ŗā†’ā˜‚ā†’ā˜¹ā†’āœ.org/
aka
http://xn--55gaaaaaa281gfaqg86dja792anqa.org/
Okay, we’ll now strip emoji strings from slug / URL.
https://github.com/discourse/discourse/commit/3566c6f02b2d1f3e84ff5cc565a8cbc676124a6b
