Small issue when a reply was made to a message which was split in another topic
Hi.
Here my topic A and its messages 1, 2, 3, 4.
  • A
    • 1
    • 2
    • 3
    • 4 (reply to 2).
I split my topic and create a new one with the selected messages, here they are now:
  • A
    • 1
    • 4 (reply to 2).
  • B
    • 2
    • 3
Now, if you go to message 4, then click on the button to display the message which was replied to (message 2), there is a quick loading and nothing happens.
You can see the issue here:
Click here: image
The target message is this one: La Slackline ! - #4 par chouch - Autour d'une roue - Monocycle.info
(I used the search function and couldn’t find any discussion about this issue, sorry if it as already discussed somewhere)
edit: I have Discourse 2.4.0.beta11. I can’t update right now though.
re-edit, I have updated to 2.5.0.beta2 and the issue remains.
Hi, just to add details, this small issue happens for any reply that is not in the current topic, so it happens with deleted replies as well.
