After upgrading, when I try to open the emojie window it’s not showing, I only see a transparent green overlay on top of the page but without the emoji window. Anyone else experiencing this?
In a support thread titled “Smilley window now showing,” Idan reported that after upgrading to v1.6.0.beta10, the emoji window fails to appear for non-admin users, displaying only a transparent green overlay. The browser console reveals a JavaScript error: Uncaught TypeError: 'set' on proxy: trap returned falsish for property 'discourse_emojis_emojiPage' Idan. While SidV confirmed the issue does not affect admins on the same version, Idan listed several installed plugins. Following advice from sam and Falco to disable plugins, Idan removed all third-party plugins and the official discourse-solved and discourse-spoiler-alert plugins, yet the error persisted. Ultimately, Idan discovered the root cause was a Chrome extension conflict; disabling all Chrome plugins resolved the issue, allowing the emoji window to function correctly. alphaman expressed happiness that the problem was solved.
Any errors in the JavaScript console of your browser?
This is the error I get in the console
Uncaught TypeError: ‘set’ on proxy: trap returned falsish for property 'discourse_emojis_emojiPage
I try to log in as a non-admin user and this error appears, it doesn’t appear for admins
Still can’t find a solution for the dissapearing emoji window, get the same javascript error in the console:
Can anyone help with this.
You can signup as a user in forum.vrgamesfor.com and try to post and add an emoji using the smiley button, you can see that the smiley window is not popping out, there is just a green overlay.
You can see the error in the console.
I tried rebaking, rebuilding the app, nothing works.
I’ve got the latest version (v1.6.0.beta10 +90), and I’m admin, I can’t say this occurs to me.
What version have you got? and what pluggins?
Same version as you (v1.6.0.beta10 +90).
Plugins:
discourse-affiliate
discourse-detailes
discourse-solved
spointer alert!
discourse-topic-previews
docker_manager
lazyYT
poll
Remove plugins till it starts working
Is there a way to disable them one by one in the admin without remove one and rebuilding (which takes a long time)?
Nope. Remove all and rebuild.
I removed all the plugins except the official ones (docker_manager, discourse-spoiler-alert, discourse-solved) and I still get the following error:
_application-708e307….js:1851 Uncaught TypeError: 'set' on proxy: trap returned falsish for property 'discourse_emojis_emojiPage'
This happens only for non-admin users.
Any ideas?
Try to remove the official plugins too. Except the docker manager.
It’s a chrome isse. I removed all the plugin and the issue still there, so I disabled all the Chrome plugins and I can see the window. Thanks for helping me out.
I am happy that you got it working ![]()
