Solved topic cannot be loaded
Hello :wave:
On my site we have some solved topics which cannot be loaded.
Message (2 copies reported)
NoMethodError (undefined method `user' for nil)
app/controllers/application_controller.rb:506:in `render_json_dump'
app/controllers/topics_controller.rb:1387:in `block (2 levels) in perform_show_response'
app/controllers/topics_controller.rb:1377:in `perform_show_response'
app/controllers/topics_controller.rb:191:in `show'
app/controllers/application_controller.rb:427:in `block in with_resolved_locale'
app/controllers/application_controller.rb:427:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:35:in `call'
lib/middleware/anonymous_cache.rb:410:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:26:in `call'
lib/middleware/default_headers.rb:13:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:385:in `call'
Backtrace
plugins/discourse-solved/lib/discourse_solved/topic_view_serializer_extension.rb:21:in `accepted_answer_post_info'
plugins/discourse-solved/lib/discourse_solved/topic_view_serializer_extension.rb:13:in `accepted_answer'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):75:in `_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in `as_json'
activesupport (7.2.2.1) lib/active_support/json/encoding.rb:23:in `encode'
activesupport (7.2.2.1) lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in `to_json'
multi_json (1.15.0) lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json (1.15.0) lib/multi_json/adapter.rb:25:in `dump'
multi_json (1.15.0) lib/multi_json.rb:139:in `dump'
actionpack (7.2.2.1) lib/action_controller/metal/mime_responds.rb:224:in `respond_to'
actionpack (7.2.2.1) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:226:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
i18n (1.14.7) lib/i18n.rb:353:in `with_locale'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:77:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (7.2.2.1) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `instrument'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:76:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.2.2.1) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:163:in `process'
actionview (7.2.2.1) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack (7.2.2.1) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (7.2.2.1) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:896:in `call'
rack (2.2.13) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.13) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.13) lib/rack/head.rb:12:in `call'
actionpack (7.2.2.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.13) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.13) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster (2.20.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.2.2.1) lib/rails/rack/logger.rb:41:in `call_app'
railties (7.2.2.1) lib/rails/rack/logger.rb:29:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/request_id.rb:33:in `call'
rack (2.2.13) lib/rack/method_override.rb:24:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/executor.rb:16:in `call'
rack (2.2.13) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:334:in `call'
message_bus (4.4.1) lib/message_bus/rack/middleware.rb:60:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties (7.2.2.1) lib/rails/engine.rb:535:in `call'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.13) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.13) lib/rack/urlmap.rb:58:in `each'
rack (2.2.13) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
That’s odd the other solved topics are loads fine. I tried to looking for a pattern why but seems there is nothing special. I tried it with safe mode too but the issue is still exist.
It’s maybe related with this update: https://github.com/discourse/discourse-solved/pull/347
Thank you :slight_smile:
Does enabling the show_who_marked_solved setting allow the posts to load?
I tried that too but unfortunately no. :confused:
So It seems the issue happens when the user (who has the accepted answer in the topic) has been deleted and the accepted post is also removed. :thinking:
Thanks! We’ll get this sorted
This has been fixed here: FIX: Some solved topics have no answers by nattsw · Pull Request #350 · discourse/discourse-solved · GitHub
Extra note:
When using custom fields, there are very little validations available so marked answers may be dangling, leading to posts that do not exist, or topics pointing to the same post.
We just moved discourse-solved away from using custom fields into proper tables, and there had been some assumptions made like each post should only be an answer to a topic, or a topic with an answer must point to a non-null post. All these assumptions were thrown out of the window
This topic was automatically closed after 4 days. New replies are no longer allowed.
