This is on an iPhone Xs Max.
When it first loads the ‘X’ to close is up by the notch:
After loading content it adjusts:
Sometimes, though, it doesn’t update to the second screen, and there’s no way to exit.
Just to confirm, you’re running the latest version of the app?
I think so?
I have 1.6.0 (1mo ago) according to the app store. No newer version is showing available. I can’t find a version number in the app or in Settings.
I did experience this once or twice with 1.6.0, but haven’t since I switched to the 1.6.1 build on TestFlight.
Thanks, I’ll push the 1.6.1 beta up to the App Store now, maybe that’ll fix it for you too Andrew.
It seems less frequent but is still happening occasionally.
