Space issues, recent
The discussion revolves around increasing issues with disk space on Discourse instances, prompted by a recent image update. JagWaugh raises concerns about insufficient space during updates, noting that the minimum required space may have increased. Falco responds by implementing a check in the rebuild command that warns and exits if less than 5GB is available on the Docker storage path. JagWaugh suggests enhancing this by warning admins if space would be insufficient for the next backup after an update, to prevent system failures. Falco agrees, proposing app-level warnings, possibly linked to backup failures. codinghorror recalls a similar check in the older setup script and questions its placement in launcher. Falco demonstrates the new cleanup feature, which offers to remove unused Docker images, containers, and volumes to free up space, even when disk is nearly full, and allows users to skip the check with --skip-prereqs.
Is it my imagination or is there an epidemic of “running out of space” problems lately?
I can’t remember for certain, but I think the 30 minute install used to mention minimum disk space 8 G.
What is the absolute minimum for an instance with OS, Docker etc, the running docker images, 1 backup, retention 1 backup, and enough left over to do ./launcher cleanup, then rebuild app ?
Probably worth mentioning in the 30 min install.
This is expected, we recently forced everyone on a new image.
@Falco we should perhaps add to your list to have rebuild offer to do a cleanup if you are close to the edge.
https://github.com/discourse/discourse_docker/pull/357
I went with this approach:
On rebuild or bootstrap if the user has less than 5GB on the /var/lib/docker path, we print a warning and exit.
Pretty sure we had this check before (in discourse-setup script), but maybe not on rebuild?
I remember @sam was very unhappy about the idea that any setup checks would happen in launcher.. is this space check OK there @sam?
5GB should be enough headroom for the update, at least for a while. I would suggest warn and exit if less than that is fine, but I think it might make sense to get the size of the last backup, and if (after the update) there won’t be enough space for the next backup, then at least warn, or better yet give them the choice.
That way they are aware that they have to do something about space before it becomes a show stopper. At the moment some of the support questions are urgent because the forum stops working. Warning the admin that they’re about to ring the bell may make them be a bit more proactive.
Cool. I just made the script use the correct docker storage path, when a user customize it.
I think this should be an warning in the app, possibly an extension to this.
That would be fine. We’re talking about the difference between Discourse warning you that your instance might stop working soon, and it just informing you that it has already stopped working (in the CLI) or failing to update via the GUI.
Warnings are less stressful than a broken installation (for the admin) and if they include a link to some basic triage then admins who don’t ignore the warnings may be able to resolve the issue themselves, rather than posting here on meta with “My instance is broken, what do I do?”
Some rough idea of the RAM footprint (over time) of the instance would be great, down at the bottom of /admin where it shows space. The way I see it there are a lot of support topics which resolve down to RAM and disk space problems - warnings might reduce how often people need support.
root@test:/var/discourse# ./launcher rebuild app
You have less than 5GB of free space on the disk. You will need more space to continue
Would you like to attempt to recover space by cleaning docker images and containers in the system?(y/N)y
WARNING! This will remove:
        - all stopped containers
        - all volumes not used by at least one container
        - all networks not used by at least one container
        - all dangling images
Are you sure you want to continue? [y/N] y
Deleted Images:
deleted: sha256:819eeb6f03508bc5bc3513b1c3ad15676f89eca0aad3e9cd5aee91814232c659
deleted: sha256:ee29540380f982c413b738107117efd9ea47ccbf7a734a4a6b599f6fadf48d80
deleted: sha256:8fa33f3175ab8c85b934f5de02b23d3b4f006e947a63c7b2e8ed9f00b4120784
deleted: sha256:4dc0122075eb31044391c92fbfe3427faa6247b87b62d9872e94072891776de1
deleted: sha256:9b2efd6b6ef11f51e7109b006e852d5a672db6b48a5a7e38f9f1a0ade1abc772
deleted: sha256:24f0df43021665bd15bf59945554929c0cea86e21828de355a4154d707bdee9b
Total reclaimed space: 2.651 GB
If the cleanup was successful, you may try again now
This is done using the new Docker clean, and will work even if you have 0 bytes available. We also try to detect the correct folder for space.
If this brings any problem for you please open a Contribute > Bug topic, and remember you can always skip this with --skip-prereqs.
