בקשת צוות
Hello! Is it possible to have applications on here? Like a google form but on the forum?
You mean a dedicated space for staff applications on your forum?
You can create a category for that. Or ask for PMs to the current staff group.
I know what you mean. I have wanted this feature as well but I think there is a way to achieve this through the user group. When a user requests to join a user group, the owner of that group will get a notification. Then perhaps a category can be created that has a specific template (like a form) where they can fill out and answer any questions.
I used to do this one of two ways:
  1. You can create a custom link, which will pre-fill new topic or pm, so user will have a template :
    Creating pre-filled personal message links
  2. If you need more customisation and something more sophisticated, you can also use this plugin:
    Custom Wizard Plugin 🧙 - #463
    Good luck!
Ah alright, I see the Custom Wizard Plugin has fields. Thank you!
