I spent some time exploring tags today, and came across a few UX issues.
Firstly, are tag groups designed so that each tag can be in multiple tag groups? If not, could it be an admin setting to enforce this?
Then if so, it would help if the filter used when adding tags to a tag group excluded any tags that are already in a tag group. Right now it appears to only exclude tags used for the current tag group you are managing.
It would be so nice to have UI for assigning a tag to a tag group from the tag edit page. Right now you can only rename the tag but it would be helpful to be able to change the tag group from there.
I had multiple browser tabs open as a result, which led to another issue. I was adding tags to a tag group, and then realized I wanted to rename a tag that I had had already added. I renamed it in another tab. The old tag name was still listed as part of the tag group and I was able to add the new one.
It would need to handle multiple groups, but I guess this could be useful.
So live updates like posts? I think that would be super gold plating this UI.
Maybe it would be helpful if the tag input field there could support pasting a list of tags. That way you can work on your tag group schema in a document somewhere, and then paste a list of tags into each tag group’s tag list. The fancy tag autocomplete on that page is probably not very helpful when trying to add a lot of tags that you already know you want to add.
