Discourse has the ability to summarise long threads. My understanding is that it uses engagement metrics like reactions or number of replies to identify what posts should be kept. In my community (internal communication within the company) this almost never triggers despite threads that are 20 pages long (reply count is not the best trigger for us)
A more powerful approach would be to use an LLM like GPT-3 or BERT to summarise the whole thread on demand (vs just filtering the posts). Summarisation is a use case where LLMs shine (pretty much the poster child) and I believe this would be way more effective than the current approach which is based on weak signals (in some communities, people may not use reactions or reply to specific posts).
On the other hand, running GPT to summarise text can be expensive, up to $0.02 per 1k tokens. This feature would probably make more sense in some private communities than high-traffic public ones.
I imagine the feature to work like this:
when reading a long thread for the first time (long defined with a setting) that has never been summarised, suggest to summarise it on demand.
the summarisation would be inserted in the thread (eg: everything before is summarized)
it is linked from the top of the thread (eg: jump to the summary)
ideally, there is some feedback mechanism
after N more replies, offer to publish a new summary and update the link at the top.
the plugin would be configured with an openai key (assuming this is the LLM used). Eventually, if it proves successful, you would want to offer access to different models.
At least that’s the theory . In practice there are unknowns about how good it would be, or how to configure the degree of summarization. My instinct is that this is extremely high ROI for some communities. The number one problem I hear is that people hate catching up on threads. This would be of massive help.
import openai
import requests
from bs4 import BeautifulSoup
openai.api_key = "KEY"
url = "https://meta.discourse.org/t/summarising-topics-with-an-llm-gpt-bert/254951.json"
response = requests.get(url)
data = response.json()
messages = []
messages.append("Title: " + data["title"])
for post in data['post_stream']['posts']:
soup = BeautifulSoup(post['cooked'], 'html.parser')
messages.append("Post #" + str(post["post_number"]) + " by " + post["username"])
messages.append(soup.get_text())
text_blob = "\n".join(messages)
print(text_blob)
max_chunk_len = 4000 # Maximum length of each chunk
chunks = [text_blob[i:i+max_chunk_len] for i in range(0, len(text_blob), max_chunk_len)]
summaries = []
for chunk in chunks:
print("processing chunk")
response = openai.Completion.create(
engine="text-davinci-003",
prompt="prompt:\n" + chunk + "\nsummary:",
temperature=0.7,
max_tokens=200,
top_p=1,
frequency_penalty=0,
presence_penalty=0
summary = response.choices[0].text.strip()
print("\nSUMMARY")
print(summary)
print("\nSUMMARY")
Discourse is exploring the possibility of using an LLM such as GPT-3 or BERT to summarize long threads on demand. This feature would be configured with an openai key and could be especially useful for private communities. The summarization would be inserted in the thread, with a link at the top and a feedback mechanism. The AI team is currently exploring this possibility and will update when they have something to show.
@Julienlavigne I’ve made some significant improvements to this in terms of stability, flexibility and administrative feedback.
Errors returned by the model are now logged, for example, so you can now easily tell if you’ve breached model limits.
If you (or anyone) wants to give it a try I might be able to provide a little casual support for it for a little while and may be able to incorporate feedback where reasonable.
Sadly I’m using the business version of discourse and can’t deploy custom plugins, so I can’t test this easily. I may try to run discourse locally with a backup and play with it though. I’ll keep you posted.
